Go to Post If that many teams could do it successfully every match this year I will eat my robot. - Jay O'Donnell [more]
Unread 09-01-2012, 00:33
Charmander's Avatar
Charmander Charmander is offline
None #1714
Charmander can only hope to improve
Mecanum vs The Barrier
My team is strongly considering Mecaum this year. However, we are a little concerned about the 4 inch high steel barrier. We did some tests and our 8 inch mecanum bot can go over the barrier without too much problem. However, we are a little concerned about if the mecanum wheels will get worn out over time. The wheels are delicate and ramming into the 4inch high steel barrier can't be the best thing. We might go for 10inch heavy duty mecanum wheels but would either set of wheels get worn out considerably?
Unread 09-01-2012, 00:39
Andrew Lawrence
Posts: n/a
Re: Mecanum vs The Barrier
To put it delicately: Those wheels are gonna be broken in 2 by match 3.
Mecanums have no traction, and worse, are very fragile. Most teams will be going full speed to get over those ramps, and if you do that with mecanums, then they'll get broken before they become useful. Not to mention, it'll be hard to get any traction on the bridges.
If you do use mecanums, then be careful, use them the grippiest way possible, and double check your choice.
Unread 09-01-2012, 00:41
Unglued Unglued is offline
AKA: Andrea Valenzuela
None #0865 (Warp7)
Team Role: Animator
Unglued is on a distinguished road
Send a message via AIM to Unglued Send a message via MSN to Unglued
Don't do that if you want the wheels to last..
The barrier can be overcome with enough momentum but your wheels and frame are taking a hit every time.
Unread 09-01-2012, 01:11
Joe Schornak's Avatar
Joe Schornak Joe Schornak is offline
No Stranger To Love
FRC #2840 (Blue Tide)
Joe Schornak is a splendid one to beholdJoe Schornak is a splendid one to beholdJoe Schornak is a splendid one to beholdJoe Schornak is a splendid one to beholdJoe Schornak is a splendid one to beholdJoe Schornak is a splendid one to beholdJoe Schornak is a splendid one to behold
My team is prototyping a variation on a mecanum system that should reduce the impact on our wheels. Each mecanum wheel will be paired with a traction wheel positioned ahead of the mecanum and raised so that it doesn't contact the ground while driving normally. When the robot drives over the barrier, the traction wheel will contact the barrier first and lift the front of the robot, putting the mecanum wheels in a more advantageous position to drive over the barrier. I'll probably post a picture or a detailed drawing once our design is more finalized.
We used mecanums last year and in a 2010 summer project, and have never encountered the problems usually associated with them. They have excellent traction on a variety of surfaces, and while a mecanum bot wouldn't win a pushing contest against an 8-wheel roughtop-treaded gear-shifting defensive beast, we have pushed tank drives around with no problems. Our newest set of wheels, from AndyMark's current line of mecanums, have survived use on multiple robots, and they will survive through this year's competition. As long as you design your drive system so that the barrier impact point is not at the very front of the wheel, so more of the force is directed into pushing the bot over the barrier than into deforming the wheel, you should have no problems.
1. Acquire Manual
2. Read Manual
3. ???
4. PROFIT!
Visit www.pcdsrobotics.org!
Unread 09-01-2012, 04:48
Chickenonastick's Avatar
Chickenonastick Chickenonastick is offline
Not a kebab
FRC #3256 (WarriorBorgs)
Chickenonastick is on a distinguished road
Just imagine what the bump will look like following a regional.
Unread 09-01-2012, 11:56
Charmander's Avatar
None #1714
After reading all the posts so far, it seems that more people believe the mecanum wheels will be able to handle it. Would it be wise to put in the money (and weight) to buy the 10 inch heavy duty wheels over the 8 inch wheels?
Unread 09-01-2012, 12:41
mesamb1's Avatar
mesamb1 mesamb1 is offline
AKA: Sam Bacon
FRC #1466 (Webb Robotics)
mesamb1 is just really nicemesamb1 is just really nicemesamb1 is just really nicemesamb1 is just really nice
Depends on the rest of your robot. If you need a low center of gravity, or to be close to the ground to pick up balls I would stick with 8"(My team has the 8" and I am unable convince our students not to use them). but if your have other factors that would need a ten get them.
Unread 11-01-2012, 20:50
mayde's Avatar
mayde mayde is offline
Team Captain / Pirate Queen
AKA: Mayde Smith
FRC #2865 (Roboteknix)
mayde is on a distinguished road
Send a message via MSN to mayde
If you're absolutely set on using mec wheels, but are worried about the wheels not holding up under the repeated stress of climbing, i definitely recommend making your own. in 2010 we made our own and the process was repetitive and a little bit tedious but fairly simple, and if you do them the same way we made ours, they'll be very sturdy. another bonus is that you can cast the rubber for the rollers in your own team color and have the hubs galvanized to look pretty also. if you want something to reference, you can look at my team's wheels on our website (http://www.roboteknix.com/gallery/?&...71623918928449) or even look further in the past: in 2006, with the game Aim High, team 357 made their own mecanum wheels that they dubbed "Jester Wheels".
Just food for thought if you have a little time and patience on your hands.
Surprise.
Roboteknix 2865;
2010 Spirit- Portland Autodesk Regional
2011 Safety Captain - Seattle Regional
2012 Team Captain- Cheney (Spokane) Regional
Unread 11-01-2012, 21:16
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
video proof of Mecs driving up and balancing on this year's bridge.
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
Unread 11-01-2012, 22:06
Djur's Avatar
Djur Djur is offline
WPILib
AKA: Sam Carlberg
Djur will become famous soon enough
Getting off it is a problem with our 2011 bot, though, because it's so top- and front-heavy (it almost tips over each time we drive off).
WPILib dev (RobotBuilder, SmartDashboard, GRIP)
Unread 11-01-2012, 23:48
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
so you were the ones that made those (saw the pic on wikipedia)... very nice!
if you have CNC access or at least a very skilled machinist, I guess you can make those... not for the faint of heart I'd say.
Unread 12-01-2012, 00:07
If you'd like to play around with the numbers, there's a small 16-bit mec roller design app (sorry, won't run on 64-bit Windows) at this page. Click on the "2011-09-30a mecanum roller design calculator " download link.
You enter desired wheel radius, roller center radius, and number of rollers, and you get the information shown in the attached screenshot, plus an XY data file of the required roller profile. It's easy to iterate to try different solutions. The solutions are for a "bumpless" mec: the wheel circumference is circular with no gaps.
Unread 09-01-2012, 00:43
Marc S.'s Avatar
Marc S. Marc S. is offline
Read the Manual! PLEASE!
AKA: Adversity
FRC #3925 (Robotics)
Marc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond repute
Keep in mind, the barrier has a 1/4"(1/2"round) fillet on both edges, this will reduce wear.
SuperNerd256, pneumatic wheels will go flat, and the mecanum rollers are replaceable.
Alumnus FRC 973: 2010, 2011, 2012, 2013
2011 World Championship Winning Alliance Member
FLL Mentor and Competition Judge 2012-2015
Student-Mentor FRC 5102: 2014, 2015
Student-Mentor FRC 3925: 2015, 2016
FRC Ventura Regional Planning Committee Member & Regional Field Supervisor: 2015, 2016
Unread 09-01-2012, 00:46
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Unless you put "skis" about a centimeter off the ground.
Unread 09-01-2012, 00:49
MattC9's Avatar
MattC9 MattC9 is offline
MattC9 has a spectacular aura aboutMattC9 has a spectacular aura aboutMattC9 has a spectacular aura about
We used mechs. in 2010, never again. They were destroyed because of the 2010 bumps, I can't immagine what the barrier will do to them.
