FRC 2012 Ball Launcher by iR3
Check out our 2012 ball launcher / shooter: http://youtu.be/DO0XzkthMUs?hd=1
The purpose of this particular launcher was to try different configurations and parameters such as wheel rpm, wheel spacing and wheel width. We also wanted to be able to adjust these configurations precisely and quickly. Over the next few days we will be trying various wheel configurations and materials to improve launch distance and consistency. We believe this exact design could serve as a final shooter with the correct control parameters and motor selection but there is obviously a fair amount of structural / mechanical optimization that could take place. /edit With Tech Specs Tech Specs: Wheels: 6" FRC 2008 KOP wheels Motors: 2x CIM Gear Used: 14 tooth to 40 tooth 1 stage Center To Center Wheel Spacing: 12" ( creates 6" opening ) Distance between wheels: 3.625" insides Last edited by Dan Richardson : 10-01-2012 at 10:41. |
Re: FRC 2012 Ball Launcher by iR3
Cool. Jealous.
Now to compact that design and strap it to a turret. |
Oh and turrets? ::cringes:: Quote:
In competition, many teams don't have the resources to constantly change out for fresh material, simply adjusting the wheel spacing will compensate for wear. So even tho this is a prototype, we'll probably leave that part in on the final design ( if any of our teams shoot that is :-) ) Oh, and at the 50 second mark, slijin is correct, he fumbled the ball and it kicked back off wheel which brings me to my next topic, consistency: Quote:
A major observation from our experimenting is the importance of consistency in ball feed to the shooter. We noticed if the ball was fed slightly to one side or the other the angle and distance could change considerably. Teams will need to ensure that the ball is consistently guided into the shooter if they want to be accurate and precise! Quote:
Our next test will be with at a higher RPM as our gear ratio is currently 2.85:1 (14tooth cim, 40tooth .5"hex) we just didn't have a bigger cim gear on hand. Quote:
If we can get access to a few of the smaller motors maybe we'll try it and post a new video. |
@ Dan this reminds me alot of 1251's 2006 prototype. The modulox seems to be the perfect way to test out a shooter this year, very impressive. @ Ninja The wheels will lose momentum when a ball is shot so you either have to have a controlled feed to wait till the wheels ramp back up or have a diffrent shooting system. Dan, why are you so scared of turrents, they worked fine for 1902 in 2009 hehe.
I thought that the balls would be to soft to be used in a machine like that. But that is REALLY nice.
Store Credit?
#7
thats a cool idea my team mentor and builder like it, funny thing is im not a builder im a programer
#8
Yes very similar design indeed! :: The opinions stated in this post are that of the author and not of his company, management or mentored teams :: I believe at the upper levels of competition turrets will be very successful. However, there are a few complex systems that have to work perfectly to make a turret design successful i.e. drive train, bridge balance, intake, delivery and shooter. Once a design and prototype is developed and those systems are perfected then and only then would I personally start on a turret.. which would probably be in 2013. But hey, that's just like... My opinion man.. Quote:
#10
After making seeing that shooter the dimensions of the robot are starting to look a lot smaller! Hopefully it can be successfully compacted.
#11
Though this setup could theoretically serve as a final design, the point of the shooter was to help answer the practical questions while designing the final solution. Questions like what trajectories work best for long rage shots at the top goal. We tested that in a recent video seen here: http://www.youtube.com/watch?v=l8U9u2iqMEs&sns=em On the other hand, our final design will definitely include room for modularity and adjustability so that we can continue to iterate and improve on the design. Last edited by Dan Richardson : 11-01-2012 at 12:26. |
#12
This is very similar to the shooter we got up and running last night. We designed for all the same adjustability, but not having the Modulox components to make that trivial it took several hours. However it works similarly well. We are unable at the moment to get the speed up to what we would like due to gearing constraints (again where Modulox would be awesome), but are VERY pleased with consistency and should be able to get the speed we need just by gearing down less (the torque seemed more than sufficient). No video yet, but soon.
#13
nice job! good music, too.
would you be willing to do some controlled tests to compare it against my trajectory spreadsheet and post the results? Mostly, I'd like to see you use your fixture to estimate launch velocity based on range. Mount that sucker to a desk to make it the right height and lock down the angle on it. Feed the balls as nicely as possible and check the distance traveled against numbers from my sheet. It will go a long way to helping us figure out what the drag effect will look like. |
#14
We could calculate wheel speed rather simply but it may be difficult to determine the balls acceleration through the shooter. Right now my only thought is high speed camera or some sort of photo gate. Am I over complicating this? Any thoughts? |
#15
Could you give us an indication of what kind of rpm you were spinning those wheels at for the various ranges?
