Go to Post I firmly believe that it's within your power to aspire instead of lament. - Alan Anderson [more]
Unread 10-01-2012, 17:39
Fuego247's Avatar
Fuego247 Fuego247 is offline
FRC #0247 (Da Bears)
Team Role: Electrical
Fuego247 is an unknown quantity at this point
4 gripping wheels
If a robot running tank drive with 4 2011 kit wheels in the corners turns, will the robot bounce or jostle around? Or will it turn normally. I believe it will turn normally, but I am being told otherwise. Any examples of robots that bounce or do not bounce?
Unread 10-01-2012, 18:17
Ernst's Avatar
Ernst Ernst is offline
Ernst
AKA: Ernst
FRC #1732 (Hilltoppers)
Ernst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond repute
Re: 4 gripping wheels
The larger your wheel base is, the more likely you are to skid while turning. If you have a wheel in each corner of your robot and you try a turn (assuming you're using tank drive), then the answer is yes, you will skid.
For questions about different drivetrains, you can always hit up the FirstWiki.
Unread 10-01-2012, 21:56
DonRotolo's Avatar
Back to humble
FRC #0832
It's possible that it won't, but I'm guessing a higher-than-50%-chance that it will, on carpet.
The best way to know is to try it.
