Go to Post Don't give up on others. I believe in killing grumps with a smile! - maltz1881 [more]
Unread 11-01-2012, 00:33
CrashTestPilot's Avatar
CrashTestPilot CrashTestPilot is offline
AKA: Rafal Myslak
FRC #2338 (Gear It Forward)
CrashTestPilot is an unknown quantity at this point
6 wheel wide chassis - is there any advantage over just 4 wide?
Is there any advantage to using 6 wheels in a wide tank drive configuation? Assiming you can fit 3 wheels on each short side. Would you even consider 6 wheel with center dropped in a wide configration? Sounds to me that the very short "wheelbase" created by the 4 wheels that are in contact with the ground would make the robot very tippy.
So what about turning effort in a wide chassis. If all wheels are in the same plane, would there be any difference in amount of scrubbing and turning effort between 4 wheel wide and 6 wheel wide. Assume wheel size to be the same.
Unread 11-01-2012, 00:37
VKP's Avatar
VKP VKP is offline
VKP
AKA: Vivek Paramasivam
FRC #1899 (Saints Robotics)
VKP is an unknown quantity at this point
Re: 6 wheel wide chassis - is there any advantage over just 4 wide?
A wider chassis would definitely be easier to turn, but in this year's game, balance is very important when getting over the barrier and the ramps, and a wide robot would be more susceptible of falling over backwards or forwards over those field elements.
Vivek
Treasurer, Senior Build Officer, Saints Robotics 1899
Seattle Olympic Regional Chairman's Award 2011
Seattle Olympic Regional Winner 2011 (Thanks 2990 & 3393)
Seattle Olympic Regional Best Website Award 2011
Unread 11-01-2012, 01:29
Marc S.'s Avatar
Marc S. Marc S. is offline
Read the Manual! PLEASE!
AKA: Adversity
FRC #3925 (Robotics)
Marc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond repute
The reason for building a 6wd is so the bot can turn better. So i ask you, how do you make a 4wd turn better?
(the answer is: By adding center wheels(effectively making it a 6wd).)
In 09 a lot of teams went wide and thought that because they are wide turning with 4 wheels will be just as easy as a long 6wd. Yet with a trailer and a lot of heavy defense, wide bots with either swerve drive or 6wd triumphed in turning capabilities and escaping defense.
Alumnus FRC 973: 2010, 2011, 2012, 2013
2011 World Championship Winning Alliance Member
FLL Mentor and Competition Judge 2012-2015
Student-Mentor FRC 5102: 2014, 2015
Student-Mentor FRC 3925: 2015, 2016
FRC Ventura Regional Planning Committee Member & Regional Field Supervisor: 2015, 2016
