Go to Post Have you been formally diagnosed as a masochist, or are you just a mentor? - GeeTwo [more]
Unread 11-01-2012, 15:11
WittyUsername's Avatar
WittyUsername WittyUsername is offline
FRC #3607 (Technologic)
WittyUsername is an unknown quantity at this point
Robot Dimensions
Hey Everybody, just a quick question:
the robot's dimensions are restricted to 28" by 38". However, are we able to switch those dimensions, i.e. rotate the robot 90 degrees and get a bit more length in the front of the robot?
Thanks for all your help!
Unread 11-01-2012, 15:13
avanboekel's Avatar
avanboekel avanboekel is offline
AKA: Adam Van Boekel
FRC #5934 (Gear it Forward, Crowbotics)
avanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant future
Re: Robot Dimensions
Yes, its perfectly legal. You will need to be careful with going over the bump and bridge though. You have a greater chance of tipping.
2338 Gear It Forward | Student 2010-2013 | Mentor 2014-Present | oswegofirst.org
2013 Wisconsin Regional Winner (1732, 111, 2338)
2013 Midwest Regional Dean's List Finalist
2015 Midwest Regional Chairman's Award Winner
2015 Archimedes Subdivision Winner (1023, 2338, 3996, 1089)
2016 Midwest Regional Chairman's Award Winner
4096 CTRL-Z | Mentor 2014 | team4096.org
5934 Crowbotics | Mentor 2016-Present | crowbotics.org
Andrew Bates's Avatar
Andrew Bates Andrew Bates is offline
AKA: Bates
FRC #0125 (NUTRONS)
Andrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond repute
There is no rule that restricts one of those dimensions to be the "front" of your robot. It could be either the 28" or 38" side.
ME Student at Northeastern University, Captain of the NUTRONs #125 FRC
Former member of VEXELLENT and Cranbrook Robotics
Unread 11-01-2012, 15:14
JDBohanon234 JDBohanon234 is offline
FRC #0234
JDBohanon234 is an unknown quantity at this point
Most definitely. That is a common factor determining center of gravity and other physical aspects of design. A robot with the front and back sides shorter that the other two is generally known as narrow or long oriented, while when you flip that, bots are known as wide oriented.
Unread 13-01-2012, 00:30
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
3 on a bridge
For 3 on a bridge purposes, you want the wheels parallel to the 28" side (bot as short as possible). 3 bots 28" long, with 3" bumpers, can fit with 1" frame overhang on each end.
Unread 13-01-2012, 02:10
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
Re: 3 on a bridge
I'm getting 4" chassis overhang on each side
((28+3+3+28+3+3+28)-88)/2
Unread 13-01-2012, 02:19
Marc S.'s Avatar
Marc S. Marc S. is offline
Read the Manual! PLEASE!
AKA: Adversity
FRC #3925 (Robotics)
Marc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond repute
Re: 3 on a bridge
Bumpers are 3.52" thick. About 5" of overhang on both outer robots or 10" of overhang on the third bot to drive on the ramp.
Alumnus FRC 973: 2010, 2011, 2012, 2013
2011 World Championship Winning Alliance Member
FLL Mentor and Competition Judge 2012-2015
Student-Mentor FRC 5102: 2014, 2015
Student-Mentor FRC 3925: 2015, 2016
FRC Ventura Regional Planning Committee Member & Regional Field Supervisor: 2015, 2016
Unread 13-01-2012, 02:42
WizenedEE's Avatar
AKA: Adam
Re: 3 on a bridge
Rules say 2.5 inch tubes and .75 inch plywood <R27 A and C>, and can be a maximum of 3.5 inches (a maximum of 1 inch of hard stuff and a maximum of 2.5 inches of tubes). 3.25 is probably close to the correct dimension, assuming you drill holes in the plywood to fit the bolt heads on the robot.
That makes 97" long; 9 inches total and 4.5" on each side.
Unread 13-01-2012, 06:20
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Also remember those are maximum dimensions, you can always make it smaller.
Unread 13-01-2012, 09:50
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
You probably want to make it a little smaller, since robots seem to "grow" during build. We always aim for 26" x 36", yet they end up being just barely able to fit into the sizing box. And if your robot doesn't fit into the sizing box at inspection, you need to modify it so it will fit, or you don't get to put it on the arena floor to play.
Also try to make the top of the robot at least an inch smaller than the bottom. This will make up for the sizing boxes that are not "square". been there, done that
Unread 13-01-2012, 17:14
wilhitern1's Avatar
wilhitern1 wilhitern1 is offline
Sr. Systems Analyst / BRM
AKA: Neal Wilhite
FRC #1225 (Gorillas)
wilhitern1 is a name known to allwilhitern1 is a name known to allwilhitern1 is a name known to allwilhitern1 is a name known to allwilhitern1 is a name known to allwilhitern1 is a name known to all
Why not robots 24 inches wide. Then they can go side by side on the ramp...
Unread 13-01-2012, 18:21
Nothing stopping you. As long as it fits in the sizing box, it's good sizewise.
