Go to Post the rookies come up with amazing stuff (I have seen it happening), they amaze me at times. - Arefin Bari [more]
Unread 11-01-2012, 20:42
TimSchley's Avatar
TimSchley TimSchley is offline
AKA: Tim Schley
FRC #0997 (Spartan Robotics)
TimSchley is an unknown quantity at this point
Help making the Driver Station run on logon
Hello all!
I am having some issues in trying to make the Driver Station run on the startup of the Driver account. I have tried putting a link to the program in the "Startup" folder running as administrator, and also I have looked at this post:
Originally Posted by Darnax View Post
If you really want to get fancy and have the driver account bring you to the driver station instead of the desktop (like I did with my laptop) just do the following:
NOTE: This must be done on the Driver Account so it only affects it. Make sure you have a separate Administrative Account so you can still makes changes to the computer.
WARNING: I take no responsibility for any damage you do to your computer by modifying the registry. This is entirely your own choice.
1. Go to the start menu
2. Go to Accessories > Run
3. Type in regedit and click OK.
4. Once the Registry Editor is open navigate to HKEY_CURRENT_USER/Software/Microsoft/Windows NT/CurrentVersion/Winlogon
5. Create a new String Value (Right Click > New > String Value) called Shell and set its value to the location of the driver station on your hard drive. (Should be "C:\Program Files\FRC Driver Station\Driver Station.exe")
6. Log off and back on to the driver account and the computer should enter the Driver Station automatically.
Alternatively you can use the following files I wrote (on the Driver Account) to add or remove the modification (assuming your Driver Station is installed to the default location and the computer is not a 64-bit system):
Add Modification: modify.reg
Remove Modification: heal.reg
Notice: To access the desktop on a modified account for any reason just get to the task manager with ctrl-alt-delete, go to processes, file, new task, and type in explorer.exe.
and followed the instructions (except using program files(x86) because it is a 64-bit computer). This also did not work.
Any ideas of what might be wrong or what we might do to fix this?
Unread 14-01-2012, 23:24
ProgrammerMatt ProgrammerMatt is offline
Programmer-Electrical-Mechanical
FRC #0228 (Gus)
ProgrammerMatt is just really niceProgrammerMatt is just really niceProgrammerMatt is just really niceProgrammerMatt is just really nice
Re: Help making the Driver Station run on logon
Does it do anything when it starts up? black screen?
Unread 15-01-2012, 05:01
TimSchley's Avatar
AKA: Tim Schley
It loads up windows like normal.
Unread 15-01-2012, 20:23
FRC #0228 (Gus)
Then somthing in the registry that you edited is wrong is should boot in shell (black screen)
Unread 15-01-2012, 22:00
inkspell4's Avatar
inkspell4 inkspell4 is offline
FRC #3650 (Robo Raptors)
inkspell4 will become famous soon enough
For our team we just imaged it than ran the driver station install/update and it works fine
Chesapeake Regional : 2013, 2012, 2011
2013 RoboRaptors Team 3650 Programming Team Captain
Team Website : http://www.roboraptorsfrcteam3650.com/index.html
_____________________________________________
Unread 19-01-2012, 18:47
TimSchley's Avatar
AKA: Tim Schley
I mean on a non-classmate computer with the driver station on it. I can't figure out how to get THAT to start up with only the driver station up.
Unread 11-02-2012, 20:33
inkspell4's Avatar
Have you tried installing the classmate image
Unread 12-02-2012, 11:32
On a non-Classmate computer? Perish the thought!
Seriously, don't try it. The E09 and E11 flash drives are intended only for the E09 and E11 Classmate. There's a very good chance that using them for anything else will result in a computer that won't boot.
Unread 12-02-2012, 13:50
inkspell4's Avatar
Isn't there a rule that says other laptops are allowed to be used in competition as long as they are setup the same way as the classmate so there must be a way to do it
Unread 12-02-2012, 14:26
We do it on other laptops just by installing the Driver Station software, not a duplicate of the Classmate operating system and drivers.
