Go to Post There will be violence next year! YAY! - Koko Ed [more]
Unread 12-01-2012, 17:48
nydnh01 nydnh01 is offline
AKA: Naresh Hing
FRC #1601 (Quantum Samurai)
nydnh01 is an unknown quantity at this point
2 Driving Modes
I was wondering if their is a way to program 2 drive modes in Labview and if they can be switched by using buttons on a joystick?
Unread 12-01-2012, 19:54
j.cole j.cole is offline
FRC #0379
j.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud of
Re: 2 Driving Modes
LabView provides 3 (if I remember correctly) drive setups. Tank, arcade, and Holonomic (Mecanum). Which all can be switched with buttons/switches/knobs/ anything. It's just going to be a lot of work.
It's not normally a good idea to give a programmer a drill but rules are made to be broken.
Unread 12-01-2012, 20:23
SuperS_5's Avatar
SuperS_5 SuperS_5 is offline
[Certified LabVIEW Developer]
FRC #1219
SuperS_5 will become famous soon enoughSuperS_5 will become famous soon enough
i wouldn't say a lot of work. maybe some thought and help from us. most of the local teams here always have a few chosen drivers, and they always want the same setup.
What is your intended use?
Give it your best shot, if you get stuck, just ask, and post some sniplets.
Mike B
Unread 12-01-2012, 23:40
AKA: Naresh Hing
Re: 2 Driving Modes
We are trying to use this function during the teleop mode of the competition so we can switch from tank drive to holonomic drive with the switch of a button.
Unread 13-01-2012, 01:15
Re: 2 Driving Modes
You are probably looking for a case structure, which allows you to switch between different things based on an input. Put your various modes in different frames, and then select them how you want.
