Go to Post You can design and theorize all you want, but the sooner you get to testing your ideas and seeing how things actually work, the better off you will be. - Andy Baker [more]
Unread 14-01-2011, 15:54
brettreardon123's Avatar
brettreardon123 brettreardon123 is offline
FRC #1212
brettreardon123 is infamous around these partsbrettreardon123 is infamous around these partsbrettreardon123 is infamous around these partsbrettreardon123 is infamous around these partsbrettreardon123 is infamous around these partsbrettreardon123 is infamous around these parts
Minibot Stored Energy Question
Having read through the minibot section of the manual, I have a question about stored energy for the minibot: would it be legal for us to use a flywheel or elastic to store energy for the minibot to use? Also, is it legal for us to launch the minibot up the pole using a pneumatic or other system installed on our main robot?
Thanks in advance,
Brett
1212
Unread 14-01-2011, 16:00
foozie's Avatar
foozie foozie is offline
AKA: Matt Howard
FRC #1124 (The ÜberBots)
Team Role: Webmaster
foozie is an unknown quantity at this point
Re: Minibot Stored Energy Question
Neither of those are legal. According to Team Update #1: Minibots must
move up the POST solely through electric energy provided after DEPLOYMENT by the permitted, unaltered battery and converted to mechanical energy by the permitted unaltered motors (and associated, appropriate circuitry).
Unread 14-01-2011, 15:59
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
check out update #1, posted on tuesday:
<G19> MINIBOTS must remain completely autonomous and move up the POST solely through electric energy provided after DEPLOYMENT by the permitted, unaltered battery and converted to mechanical energy by the permitted unaltered motors (and associated, appropriate circuitry).
(Blue Box)
<G19> means that HOSTBOTS are not allowed to launch the MINIBOT up the pole at the TARGET, or otherwise contribute to the vertical movement of the MINIBOT. Energy for vertical movement may not be stored in the MINIBOT before DEPLOYMENT (except that which is contained within the battery and excluding incidental kinetic energy stored in the motors or wheels, but NOT, for example, in a flywheel).
Unread 14-01-2011, 18:33
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
One of my co-workers pointed out that stored energy in a Li-Io battery can often be released in an extremely rapid manner by shorting the leads...
So how about this: put the battery at the bottom of a rocket shaped device, as soon as the device is attached to the rail, short the leads. When the battery explodes, the minibot/rocket will be propelled to the top....
It would take a lot of batteries....
And probably violate safety rules.....
But, it would meet the new clarification of <G19>....
Former Mentor Team 1771
Former mentor Team 4509
Unread 14-01-2011, 18:39
Actually, the blue box specifies the FTC motors. So much for creativity...
Unread 15-01-2011, 16:45
FRC #1212
Thanks everybody! One more question, is there a definition of "Deployment" in the manual? We can't seem to find it...
Thanks in advance,
Brett
1212
Unread 16-01-2011, 09:56
Look a little harder... Section 1.6 Logomotion Glossary (where all of the game- and FIRST-specific definitions are):
DEPLOYMENT – the act of positioning a MINIBOT on a TOWER. DEPLOYMENT starts when the MINIBOT breaks the vertical projection of the TOWER BASE circumference during the END GAME. (Related form, DEPLOY, verb)
Unread 16-01-2011, 13:00
DonRotolo's Avatar
Back to humble
FRC #0832
There's also a definition of when deployment ends in one of the team updates.
Unread 16-01-2011, 21:33
OScubed's Avatar
OScubed OScubed is offline
Lee Drake, CEO, OS-Cubed Inc.
AKA: Lee Drake
FRC #1511 (Rolling Thunder)
Team Role: Parent
OScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond repute
Send a message via ICQ to OScubed Send a message via AIM to OScubed Send a message via MSN to OScubed
Here's one response to this idea :
http://www.facebook.com/photo.php?pi...1ddb&id=428163
Lee Drake, CEO, OS-Cubed, Inc.
Business Mentor - team 1511
Rochester, NY
Building optimal, stable, secure solutions to your business challenges.
