Go to Post Overall I really like the idea, and don't be surprised if I borrow some of these ideas for a future robot. - Greg Needel [more]
Unread 14-01-2011, 18:22
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Minibot Stored Energy
I know the rules and updates state that energy can't be stored for the vertical projection (basically no launching, just climbing) of the minibot, or by the hostbot.
However, imagine this scenario:
Your minibot is powered by the battery, and uses motors and wheels to actually climb like intended. However, you also have a coiled up, lets say, antenna, that is unraveled after deployment, and all it does is stick straight up, and acts like a little flagpost. (Perfect for any teams with a pirate theme. ) Note that it would remain within the 12x12x12 volume constraints.
It does not help propel the minibot up, but it is "stored" energy, (by being coiled up).
I read through the rules several times but could not determine if this would be legal.
Thoughts?
Unread 14-01-2011, 18:24
Zuelu562's Avatar
Zuelu562 Zuelu562 is offline
Ready for WPI District!
AKA: Jake Janssens
FRC #3623 (Terror Bots)
Zuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to behold
Re: Minibot Stored Energy
Thoughts?
I believe that particular case falls under the "Gracious Professionalism" blanket. As long as it is determined (and possibly even demonstrated) that the use of stored energy does not contribute to vertical motion, it would be legal. Best to double check though.
Team Resume
562 "S.P.A.R.K." - Student Programmer 2008-2011, Field Coach 2011
3623 "Terror Bots" - Technical Mentor, Field Coach 2012 - Present
Volunteer Resume:
BattleCry@WPI 12, 13, 15, 16 - Queuing
BattleCry@WPI 14 - Field Reset
Granite State District Event 2014 - Team Queueing
NEFIRST District Championships '14,'15,'16 - Team Queuing
Unread 14-01-2011, 18:35
foozie's Avatar
foozie foozie is offline
AKA: Matt Howard
FRC #1124 (The ÜberBots)
Team Role: Webmaster
foozie is an unknown quantity at this point
I believe that you are not projecting the robot vertically if the bounding box (the 12" cube) stays in the same place as a result of the antenna extending, which it would according to what you said.
I believe it would be legal.
Unread 14-01-2011, 18:45
ttldomination's Avatar
Sunny
The rules say that after deployment, meaning that hostbot has moved away from the robot, the robot must use the electrical energy converted to mechanical energy by the motors.
Mechanical energy is the sum of the potential energy and kinetic energy. So say the slingshot system is on your minibot? So...legal?
1648: 2013-2014
5283: 2015
Unread 14-01-2011, 18:48
Aussie Oi!'s Avatar
Aussie Oi! Aussie Oi! is offline
FRC #3132
Aussie Oi! is an unknown quantity at this point
Thumbs down Re: Minibot Stored Energy
If it says that you cannot store energy then you should not risk it.
Because you still might be be disqualified.
Unread 14-01-2011, 18:49
If the energy is stored in the slingshot system after deployment, I'd say you could do it.
The problem is storing enough energy in 9 or fewer seconds to hit the target with 2-4N of force in 1 second after release, by using the FTC motors.
Unread 14-01-2011, 18:51
AKA: Matt B
FRC #1771 (1771)
No, it would be inspected first. If deemed illegal, either use a minibot without it, or just remove the component in question.
Unread 14-01-2011, 18:54
Sunny
Even if you store the energy in the system before the match ends. Say about...30 seconds before the match ends, the minibot uses its motors/battery to build potential energy. Then, after deployment, it's using its own electrical energy converted to mechanical energy in the form of potential energy to propel itself up the pole.
- Sunny
1648: 2013-2014
5283: 2015
Unread 14-01-2011, 18:58
- Sunny
You're storing energy before deployment.
<G19> MINIBOTS must remain completely autonomous and move up the POST solely through electric energy provided after DEPLOYMENT by the permitted, unaltered battery and converted to mechanical energy by the permitted unaltered motors (and associated, appropriate circuitry).
[bluebox]<G19> means that HOSTBOTS are not allowed to launch the MINIBOT up the pole at the TARGET, or otherwise contribute to the vertical movement of the MINIBOT. Energy for vertical movement may not be stored in the MINIBOT before DEPLOYMENT (except that which is contained within the battery and excluding incidental kinetic energy stored in the motors or wheels, but NOT, for example, in a flywheel).[/bluebox]
(emphasis mine)
You're storing non-incidental energy for vertical movement before deployment. Now, if you build it up after deployment, you should be OK; after all, you converted the electric energy to mechanical energy using the motors, then converted the mechanical energy into vertical motion.
Unread 14-01-2011, 19:02
AKA: Matt B
FRC #1771 (1771)
Eric-
As per my original question, would those rules prohibit what I was asking?
Although it is storing energy before deployment, it doesn't propel the minibot.
Unread 14-01-2011, 19:07
Sunny
Touche good sir.
1648: 2013-2014
5283: 2015
Unread 14-01-2011, 19:24
mayde's Avatar
mayde mayde is offline
Team Captain / Pirate Queen
AKA: Mayde Smith
FRC #2865 (Roboteknix)
mayde is on a distinguished road
Send a message via MSN to mayde
I don't spend much time with my nose in the rulebook, but i like to think that if it's not propelling the minibot in any way, that it should be legal. especially when you look at the spirit aspect of it.. i think it's a neat idea.
Surprise.
Roboteknix 2865;
2010 Spirit- Portland Autodesk Regional
2011 Safety Captain - Seattle Regional
2012 Team Captain- Cheney (Spokane) Regional
Unread 14-01-2011, 19:31
AKA: Matt B
FRC #1771 (1771)
Bonus (cool) points if it is timed to deploy right as the end-game trumpets sound.
Unread 14-01-2011, 19:34
Zoughtbaj's Avatar
Zoughtbaj Zoughtbaj is offline
Systems Integration Member
FRC #1983 (Skunkworks Robotics)
Zoughtbaj is on a distinguished road
Good sir, I believe you and I have the same idea in mind
The way I read it, as long as it does not apply to "move up the POST," it would not count, as the rule specifies that this only is prohibited. By moving up the post, it is implied that the force must apply to upward movement using the post, and therefore, if the movement does not directly effect your force up the post, or does not have anything to do with the the use of the post it shouldn't be prohibited, .
"The Few. The Proud. The Skunks."
Unread 14-01-2011, 19:48
Sunny
I don't see the HUGE benefit in the idea. Sure I suppose you might be able to gain 6 inches or so advantage. I suspect if you've maxed out your speed, then go for it.
1648: 2013-2014
5283: 2015
