Go to Post I just like that PVC is the most basic need of humankind according to that diagram. Whatever would we do without it?! - Po-ser [more]
Unread 14-01-2011, 09:20
Erik Huang's Avatar
Happy Birthday! Erik Huang Erik Huang is offline
Jack of all Trades, Master of None
FRC #0296 (Northern Knights)
Erik Huang is a jewel in the roughErik Huang is a jewel in the roughErik Huang is a jewel in the rough
Autonomous Scoring
Although the chances are slim, would you be allowed to pick up the opponent's dropped ubertubes and score them on your wall?
Here ye, here ye! Here cometh the robot!
Unread 14-01-2011, 09:25
Zuelu562's Avatar
Zuelu562 Zuelu562 is offline
Ready for WPI District!
AKA: Jake Janssens
FRC #3623 (Terror Bots)
Zuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to behold
Re: Autonomous Scoring
<G11> ROBOTS may not break the plane of the CENTER LINE
If that is the case, and your adversary launches the ubertube across the field, then yes, it is possible, but either something Un-"Graciously Proffesional" is going on, or some magically amazing set of events unfolded.
This event would also require that your robot cannot only FIND ubertubes on the ground, but also pick it up and take it to the peg in whatever amount of time is left.
INCREDIBLY Unlikely, but plausible.
Team Resume
562 "S.P.A.R.K." - Student Programmer 2008-2011, Field Coach 2011
3623 "Terror Bots" - Technical Mentor, Field Coach 2012 - Present
Volunteer Resume:
BattleCry@WPI 12, 13, 15, 16 - Queuing
BattleCry@WPI 14 - Field Reset
Granite State District Event 2014 - Team Queueing
NEFIRST District Championships '14,'15,'16 - Team Queuing
Unread 14-01-2011, 09:33
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
I would imagine that you could do that with your own team's dropped tubes though.
Unread 14-01-2011, 09:39
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
It may not happen until the Championship but there will be teams that will score a ubertube go back and pick up the alliance partners unused tube and score it also.
Unread 14-01-2011, 10:10
mwtidd's Avatar
mwtidd mwtidd is offline
AKA: mike
FRC #0319 (Big Bad Bob)
This is my second goal for autonomous. Yes it is legal and possible. Your robots do not need to start in their respective lanes, so potentially you could have two robots right next to each other. Also the ubertube must only be in contact with your partner so after capping your you could go back and grab it. I think its possible to achieve it with a compass, gyro and rangefinder, and be fairly accurate. If you want better than about 25% with the second cap you will have to use the camera.
Our autonomous robots typically use a mixture of "blind movements" (no sensors)" dead reckoning"(anything but the camera) and the camera. If you have the camera you can do blind movements. if not stick to using feedback from the sensors. If you want any more info just ask
Unread 14-01-2011, 10:12
mwtidd's Avatar
AKA: mike
Actually in 07 only one team achieved going back and picking up another one, also I don't know if the contact rule was in place. It was a different control system in 07 and they only accomplished this at an offseason invitational.
I believe it could happen, whether or not it will depends more on the robot designs than the programming.
Unread 14-01-2011, 11:27
GaryVoshol's Avatar
Cogito ergo arbitro
The contact rule was there:
Originally Posted by 2007 Rules
<G04> KEEPER locations - Each ROBOT may start the match in POSSESSION of one KEEPER. The KEEPER does NOT need to be contained within the ROBOT'S starting volume, however it must be in contact with the ROBOT and be entirely within the HOME ZONE. The head referee will require that KEEPERS that do not meet these criteria be removed from the game. It is the responsibility of the head referee to verify that this rule is satisfied prior to the start of the match.
(since 2004)
Unread 14-01-2011, 18:49
Erik Huang's Avatar
And what happens to the ubertube after autonomous? Is it taken out of play?
Unread 14-01-2011, 19:01
mwtidd's Avatar
AKA: mike
It is not playable, whether or not it is removed I am not sure
Unread 14-01-2011, 19:55
Zoughtbaj's Avatar
Zoughtbaj Zoughtbaj is offline
Systems Integration Member
FRC #1983 (Skunkworks Robotics)
Zoughtbaj is on a distinguished road
3.1.4 TELEOPERATED PERIOD
<G16> UBERTUBES may not be HUNG. Violation: PENALTY
bluebox<G16> disallows an unplaced UBERTUBE to be hung, a knocked-off UBERTUBE to be rehung, or movement of an UBERTUBE to a different PEG.
Based on this rule, I don't think it will be removed.
"The Few. The Proud. The Skunks."
Unread 15-01-2011, 09:43
Frenchie461's Avatar
Frenchie461 Frenchie461 is offline
iScout
AKA: Brian, Frenchie, or that guy
Team Role: CAD
Frenchie461 is a jewel in the roughFrenchie461 is a jewel in the roughFrenchie461 is a jewel in the roughFrenchie461 is a jewel in the rough
nope, <G11> no crossing the center line, sorry, you lose.
"As a general rule, the most successful man in life is the man who has the best information." - Benjamin Disraeli (1804-81)
Unread 15-01-2011, 13:50
mwtidd's Avatar
AKA: mike
Sorry, I had misread the question. The only tube you could go and grab is an alliance member's tube.
