Go to Post RoboRIO brownout (v, n): The GDC's alternative to limiting the number of motors allowed on a robot. - GeeTwo [more]
Unread 14-01-2011, 19:10
Justin Murphy's Avatar
Justin Murphy Justin Murphy is offline
Likes Waffles
FRC #0201 (The FEDS)
Team Role: Webmaster
Justin Murphy is an unknown quantity at this point
Minibot Spring?
I know that launching the minibot or any type of upward motion is against the rules but if a spring were used to grab the pole would that be legal? Rule <R92> says we can use Mechanical Hardware, a spring is mechanical hardware.
Unread 14-01-2011, 19:13
Stephen of REX's Avatar
Stephen of REX Stephen of REX is offline
FRC #1727 (REX)
Stephen of REX is an unknown quantity at this point
Re: Minibot Spring?
You'd have to ask Q&A if a spring is considered Mechanical Hardware. I would just go with surgical tubing.
Go REX!!!
Unread 14-01-2011, 20:28
EricH EricH is online now
Re: Minibot Spring?
The listed mechanical hardware is nuts and bolts and washers and stuff like that. I don't count springs as falling into that category.
Unread 15-01-2011, 11:50
bbenne0473 bbenne0473 is offline
AKA: Bruce Bennett
FRC #0201 (FEDS)
Team Role: CAD
bbenne0473 is an unknown quantity at this point
Re: Minibot Spring?
But springs are devices used to store mechanical energy. The use won't be for propulsion, just to hold things together.
With that said, won't they be considered mechanical hardware?
Unread 15-01-2011, 12:32
Basel A's Avatar
Basel A Basel A is online now
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
Re: Minibot Spring?
You may store energy for totally non-vertical propulsion. Only stored energy for vertical movement is disallowed. That I wouldn't consider springs to be mechanical hardware.
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
