Go to Post Deodorant cannot be stressed enough. To quote a teammate "body odor is a body don't-or." - C. De Vries [more]
Unread 14-01-2011, 08:51
Spirator Spirator is offline
AKA: Munaum Muhammad
Spirator is a jewel in the roughSpirator is a jewel in the roughSpirator is a jewel in the rough
Question Inventor KOP Activations
Hello, how many times can the key in the KOP copy of Autodesk Inventor be activated? We wanted to install it on a few of our lab machines for CAD.
Unread 14-01-2011, 19:16
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
joek is an unknown quantity at this point
Re: Inventor KOP Activations
i think their single-seat, single-user, in other words, once
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
Unread 14-01-2011, 21:16
rsegrest's Avatar
rsegrest rsegrest is offline
@ least I'm OVER the rock THIS time
FRC #2582 (PantherBots)
rsegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant future
Actually twice. Once on a primary computer and once on a secondary. Other than that each team member that registers with Autodesk can get a serial/product/activation code set. I have been emailing with AutoDesk over this issue. If you are installing on a machine that does not have Internet access you can submit a request to: authcodes@autodesk.com with the following information
· Your phone number
· Your email address
· Your mailing address
· Your serial number
· Your request code
and if you have any other questions you can email: first@autodesk.com
Impossible is just a big word for small men who find it easier to live in the world they've been given than to explore the power they have to change it. Impossible is not a fact. It's an opinion. Impossible is not a declaration. It's a dare Impossible is potential. Impossible is temporary. Impossible is nothing.
~ Unknown
Unread 15-01-2011, 11:13
Madmachinist13 Madmachinist13 is offline
FRC #3461
Madmachinist13 is an unknown quantity at this point
hey. where is the codes to activate the program anyways?????? i cant find them.
Unread 18-01-2011, 13:23
jakegorov's Avatar
jakegorov jakegorov is offline
Team Captain
FRC #3303 (Metallic Thunder)
jakegorov is an unknown quantity at this point
I can't find the serial number or product key for the AutoCAD Inventor that came with our 2011 KoP either. Does anyone know where to find them?
Unread 20-01-2011, 15:06
inventor_phild inventor_phild is offline
inventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant future
Your serial number should be on the plastic box that the DVD's were shipped in.
Phil Dollan
Autodesk Inc.
Autodesk Inventor and Fusion 360
Unread 20-01-2011, 15:15
Andrew Remmers's Avatar
Andrew Remmers Andrew Remmers is offline
AKA: Andrew Remmers
Andrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond repute
Send a message via AIM to Andrew Remmers
If not you can go to http://students.autodesk.com/?nd=first_home
This website sign up and download copies and get serial numbers if you need to.
Exploding Bacon 2007-2011
Built and Dangerous (B.A.D) 2011-2012
Community Mentor / School Break 2012-2014
North American Robotics: The MooseEagles Founding Member 2012-Present (VEX U)
Unread 20-01-2011, 15:17
rsegrest's Avatar
Actually our KoP disc did not come with the numbers printed on it either. I emailed AutoDesk about it and they said that there was a 'glitch'. Have you registered with AutoDesk? If not go to this link
http://students.autodesk.com/?nd=form__240
Register and then when you login there should be two links, one to download software and the other to "Get serial number and product key". Click the link and it should provide you with the info you are looking for. This is the process we had to go through to get the numbers for our copy of Inventor anyway...
~ Unknown
