Go to Post Now, everyone, say it with me: "It's just a TV show and FRC is just a robotics program. My life is a lot bigger than both of those things." Once you say this, I swear most of the arguments here would fade into oblivion. - itsjustjon [more]
Unread 14-01-2011, 21:13
ethan_orion ethan_orion is offline
FTC #0071
ethan_orion will become famous soon enoughethan_orion will become famous soon enough
[FTC]: power issues
So our robot sometimes does not engage/turn on.
When the power button is switched, the servo's twitch (small electrical signal but they do not operate). If we flip the power switch back and forth several times, finally the robot comes to life.
We've tried disconnecting and reconnecting all of the power lines between controllers.
Help!!! Thoughts?
Thanks!
Ethan
Unread 14-01-2011, 21:23
Techhexium Techhexium is offline
FTC #3555
Techhexium has a spectacular aura aboutTechhexium has a spectacular aura about
Re: [FTC]: power issues
My team has encountered servos borrowed from other teams that just wouldn't power up with our robot, but nothing like this. You mention the servo coming to life but what about your motors?
I assume one part of your robot could be failing probably to normal wear and tear, I guess it could be the servo controller, motor controller, or power switch, or bad wires or battery? I suggest you make sure your wires to your controllers don't have exposed metal at the end, that's how we blew a couple of fuses.
Unread 14-01-2011, 21:49
FTC #0071
The motors don't engage either. Really nothing works. I'm going to work through every piece of the electronics to see if i can't determine the dead piece.
Thanks.
Unread 15-01-2011, 09:17
NalaTI NalaTI is offline
AKA: Alan
FTC #2848 (Techno Guards)
NalaTI is just really niceNalaTI is just really niceNalaTI is just really niceNalaTI is just really nice
We've found that the battery/switch connectors are often a problem. Watch the Samantha module, those lights are really obvious. Then just wiggle that connection.
