Go to Post I tried to convince my team to use the force but no one would listen. - ngreen [more]
Unread 14-01-2011, 22:22
Cyberphil's Avatar
Cyberphil Cyberphil is offline
That Guy
AKA: Phil
FRC #0103 (Cybersonics)
Cyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud of
Send a message via AIM to Cyberphil
Re: 2011 Team Update #2
I'd say second harshest. Harshest is when you get a red card for your partner not passing inspection.
I would have to agree with that. I still do not get that. I get that they should be inspected, but why is it the alliances responsibility?
Unread 14-01-2011, 22:29
Chris is me's Avatar
AKA: Pinecone
I think the intent of that rule is that if the partner does not pass inspection, they must be a no-show. If the non inspected team no-shows, then you do not get a red card, but if they attempt to show to get points, then the rule thwarts that.
Unread 14-01-2011, 22:32
Cyberphil's Avatar
That Guy
AKA: Phil
I guess. I will be sure to make sure, no matter what, our alliance partners are inspected, or at least for the first 20 or so qualifications.
Unread 14-01-2011, 22:35
dag0620 dag0620 is offline
Because we're FiNE
AKA: David Givens
FRC #1071 (Team MAX)
dag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond repute
To add to that,
While I agree it's harsh, and not necessary, FIRST is clearly going for the Peer Pressure approach. With this penalty, you can bet everyone on the alliance will be pressuring other teams to get inspected, and it will probably work.
Will some unfortunate teams go under because of this? Yes. However in the end it will keep this problem to a minimal.
David Givens
Alumnus Team Max 1071 ('13) | FIRST Volunteer | NE FIRST
Away making magic for a bit...
Unread 14-01-2011, 22:43
AKA: Pinecone
Only if they're stupid enough to let a non inspected team try to show up for a match.
Unread 14-01-2011, 22:59
EricH EricH is online now
I personally think it's an overreaction to a case that happened last year where a robot that didn't set wheels onto the field ranked in the top 8 for selections.
Personally, dishing out an automatic red card to any team that wasn't inspected would be enough. But to penalize partners...
I agree on the intent; the letter doesn't quite match the intent, though. I'd agree on the peer pressure: either you pressure them to pass inspection, or you pressure them to stay far, far away from the field until they do.
P.S. If you are thinking about volunteering to inspect, do it. When there are few inspectors at an event, inspection takes forever and some teams may miss a match through no fault of their own. I think the AZ backlog last year cleared around opening ceremonies, after having an extra half-hour the night before with more inspectors to clear the line. There were still a couple of teams who had had major issues clearing by lunchtime, but that's "almost normal", and the issues were becoming more minor.
Unread 15-01-2011, 02:26
Fletch1373's Avatar
Fletch1373 Fletch1373 is offline
AKA: Fletch
FRC #3181 (Panthers)
Fletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud of
Having been an inspector for the last 2 years(2009: CT, 2010: CT, WPI, BOS, CMP), I fully agree with you. Last year, I was asked if I was available for the Boston regional, while at WPI, because of a shortage they had. All worked out fine, but I could imagine how horribly things could've gone
Student:
<04: FRC0213> <05-08: FRC1373>
Mentor:
<09-10: FRC0809> <11-12: FRC3555> <12-14: FRC0073> <15-??: FRC3181>
Volunteer:
<FTAA> <CSA> <Defense Coordinator> <Scorekeeper> <Robot Inspector> <Official Scorer>
2016 Tour:
CTWAT [DefCoord] > Pittsburgh[Mentor/DefCoord] > TVR[FTAA] > FLR[CSA] > NE DCMP[CSA] > CMP[CSA]
Unread 15-01-2011, 02:39
Rion Atkinson's Avatar
Rion Atkinson Rion Atkinson is offline
The CAD Guy
Rion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond repute
I'm sorry for this being so off topic, but what are the requirements for volunteering at a regional?
‎‎"I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. -Albert Einstein
Start Something
Email - rionatkinson@gmail.com
Skype - Rion.Atkinson
Unread 15-01-2011, 02:48
Pretty much it's be 18 or over (or parental consent) and fill out all the stuff on the FIRST website in VIMS (IIRC, it's experience, where you want to work, contact info, and that sort of thing). That should cover field reset, spare parts, and other "general purpose" spots, like field setup/teardown.
Refs and inspectors have to take a rules test and pass. Rookie inspectors will often pair with veterans for a while on Thursdays.
"Field operations lead" types have to do training at a common location.
Unread 15-01-2011, 06:37
Nadav Zingerman Nadav Zingerman is offline
FRC #2230
Nadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to behold
But can you spare the weight?
Engineering is all tradeoffs.
Also consider that bigger tanks take longer to pressurize.
Unread 15-01-2011, 07:48
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
I am not able to download the file. Anyone else having problems?
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 15-01-2011, 08:43
Back after 4 years off
FRC #5279
I can't download it either.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 15-01-2011, 09:44
GaryVoshol's Avatar
Cogito ergo arbitro
I just opened it again, and it appears it would let me save it.
(since 2004)
Unread 15-01-2011, 11:04
Bjenks548's Avatar
Bjenks548 Bjenks548 is offline
AKA: Brendan
FRC #0548 (Robostangs)
Bjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond repute
Can anyone copy and paste the rule changes on this thead for thouse of us that can't open the pdf?
Toronto Regional quarter finalists. Northville Winners/ Chairman's Winners. Troy Finalist/ GM Industrial Design Award. Michigan State Championship Finalists. CMP Newton Division winners! Triple Balance count 13. Thanks to 1075, 4307, 67, 3656, 217, 2604, 2054, 245, 118, and 2194! Photo credit for my avatar Dan Ernst
Unread 15-01-2011, 11:08
AKA: Pinecone
To sum it up:
Minibots must be deployed completely below the line.
<R66> now amended to include pneumatic cylinders and storage tanks of any sort.
<R92-O> now specifies "electrical hookup" wire (as opposed to metal wire that could be formed into springs, etc)
