Go to Post If you want to make change, you have to know what you're trying to change. - [more]
Unread 14-01-2011, 23:50
Bethie42's Avatar
Bethie42 Bethie42 is offline
AKA: Bethany Carlson
FRC #0956 (Eagle Cybertechnology)
Bethie42 is a splendid one to beholdBethie42 is a splendid one to beholdBethie42 is a splendid one to beholdBethie42 is a splendid one to beholdBethie42 is a splendid one to beholdBethie42 is a splendid one to beholdBethie42 is a splendid one to beholdBethie42 is a splendid one to behold
Re: ClassMate says no robot code?
We encountered something similar after getting the cRIO, Classmate etc reimaged: the code which happily ran our robot last season created the 'no robot code' problem. Various versions of the code all failed: this was with last season's robot, no hardware changes, it all should have run fine. We loaded the sample program provided in WindRiver [Simple Robot example, I believe] and had no problem.
I recommend that you try loading one of the example projects given in WindRiver, just to verify that it is not the same issue we had.
Incidentally, does anyone know why we had that problem? We've been theorizing that WindRiver/WPILibs had been changed enough to render the code unreadable, but it seems a bit odd.
Robot is now a verb.
We're back to square one...while we're at it, let's redesign square one!
Team 956: Celebrating ten years of FIRST!
Team record 2002-2011
2002: Highest Rookie Seed, AOR
2003, 2006, 2012: Xerox Creativity Award, AOR
2006: Semi-finalist, Sacramento Regional
2009: Quarter-finalist, AOR
2010: Quarter-finalist, AOR
2011: Semi-finalist, AOR, and Dean's List finalist, AOR
Personal record:
2008: Lead scout
2009: Lead scout, publicity
2010: Lead scout, publicity, fundraising, Chairman's, videography
2011: Team captain, lead programmer, fundraising, Chairman's, publicity, wrench-turning, Dean's List finalist at Autodesk Oregon Regional
Unread 17-01-2011, 03:20
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Most likely your code was crashing (possibly due to some change in the library). If you look at the console you should be able to tell why it's crashing or at least post the crash here so we can take a look.
-Joe
