Go to Post Contrary to the term, common sense isn't all that common. - RoboChair [more]
Unread 14-01-2011, 19:37
Damian2012 Damian2012 is offline
FRC #0904
Damian2012 is an unknown quantity at this point
ClassMate says no robot code?
The ClassMate says that their is comunnication but no robot code. Can anyone help me?
Unread 14-01-2011, 20:11
Darnax Darnax is offline
FRC #0571 (Team Paragon)
Darnax is an unknown quantity at this point
Re: ClassMate says no robot code?
I can think of a few possible reasons this could occur. Did you..
...actually download code to the robot and then restart the cRIO?
...reimage the ClassMate and the cRIO (using the cRIO imaging tool on the labview disc) to the latest versions?
...select the right development environment with the imaging tool?
...select the right file to send to the robot in preferences (may only apply to WindRiver, possibly LabView and Netbeans)?
Try these possible solutions and see if any of them do the trick.
Unread 14-01-2011, 21:52
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
If none of these work, and you're using C++ make sure of...
  • Have the correct executable selected in Window->Preferences->FIRST Downlaoder Preferences
  • Have all your network settings correct - occasionally Windriver likes to upload to a non-existant target connection without reporting an error
Unread 14-01-2011, 23:50
Bethie42's Avatar
Bethie42 Bethie42 is offline
AKA: Bethany Carlson
FRC #0956 (Eagle Cybertechnology)
Bethie42 is a splendid one to beholdBethie42 is a splendid one to beholdBethie42 is a splendid one to beholdBethie42 is a splendid one to beholdBethie42 is a splendid one to beholdBethie42 is a splendid one to beholdBethie42 is a splendid one to beholdBethie42 is a splendid one to behold
We encountered something similar after getting the cRIO, Classmate etc reimaged: the code which happily ran our robot last season created the 'no robot code' problem. Various versions of the code all failed: this was with last season's robot, no hardware changes, it all should have run fine. We loaded the sample program provided in WindRiver [Simple Robot example, I believe] and had no problem.
I recommend that you try loading one of the example projects given in WindRiver, just to verify that it is not the same issue we had.
Incidentally, does anyone know why we had that problem? We've been theorizing that WindRiver/WPILibs had been changed enough to render the code unreadable, but it seems a bit odd.
Robot is now a verb.
We're back to square one...while we're at it, let's redesign square one!
Team 956: Celebrating ten years of FIRST!
Team record 2002-2011
2002: Highest Rookie Seed, AOR
2003, 2006, 2012: Xerox Creativity Award, AOR
2006: Semi-finalist, Sacramento Regional
2009: Quarter-finalist, AOR
2010: Quarter-finalist, AOR
2011: Semi-finalist, AOR, and Dean's List finalist, AOR
Personal record:
2008: Lead scout
2009: Lead scout, publicity
2010: Lead scout, publicity, fundraising, Chairman's, videography
2011: Team captain, lead programmer, fundraising, Chairman's, publicity, wrench-turning, Dean's List finalist at Autodesk Oregon Regional
Unread 17-01-2011, 03:20
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Most likely your code was crashing (possibly due to some change in the library). If you look at the console you should be able to tell why it's crashing or at least post the crash here so we can take a look.
-Joe
