Go to Post Free time? You mean the time it takes the code to build? - axiomofdarkness [more]
Unread 15-01-2011, 00:25
Creator Mat Creator Mat is offline
FRC #2338 (Gear it Forward)
Creator Mat is a jewel in the roughCreator Mat is a jewel in the roughCreator Mat is a jewel in the roughCreator Mat is a jewel in the rough
Re: usage of denso window motor
Originally Posted by dexo568 View Post
Where can we buy a sprocket that will work with the window motor coupler? OR, can someone explain other possible ways to connect the window motor with the drive chain?
Thanks, Team 3328
What we did to attach the coupler with the was pin it to the window motor using a cotter pin. It stayed pretty well and we never had any problems with it
2010 Midwest Spirit award
2010 Midwest Quarterfinalists
2010 Wisconsin Quarterfinalists
2009 Midwest Finalists
2009 Wisconsin Quarterfinalists
2008 Midwest Rookie AllStars
Unread 15-01-2011, 01:32
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
If you have access to CNC machines (through your shop or via sponsors), you can machine your own sprockets. The Denso motors also do not like cantilevered loads, so you should always support the shaft with another bearing/bushing. Here's some 7075 aluminum sprockets with a Denso hub pattern that I machined last year for 228.
The Denso motor, sprocket, and shaft support (with Delrin bushing).
Art Dutra IV
世上无难事,只怕有心人.
Unread 15-01-2011, 02:28
Lowfategg's Avatar
Lowfategg Lowfategg is offline
Building cars now....
AKA: Tyler Moser
FRC #2016 (Mighty Monkey Wrenches)
Lowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond repute
Send a message via AIM to Lowfategg
We turned down the included KOP hub and machined the inside to press fit a bearing that would fit over the fixed metal idler shaft on the motor (I think it was 5/16"). I drilled and tapped the end of the shaft on the motor (your allowed to modify the output shafts on motors <R47>), and held it all together with a number #10 screw and washer. You can just bolt whatever you like to the modified KOP hub. Just be careful with side loads because the metal shaft on the motor is not well supported.
We used this on our ball pinching system last year with V-belts. It was a low torque application and it never failed.
Mechanical Engineering Student at WPI.
Mightly Monkey Wrenches FRC #2016 - 2010-12 (Mentor)
Past: FTC #74, FVC #3179, FVC #73, FRC #303, FRC #2753
Unread 15-01-2011, 08:11
Gdeaver Gdeaver is offline
FRC #1640
We took a 3/4" sprocket and epoxied it onto the motor. Had to ream out the sprocket hub a little. If your varying the speed of the window motor you should use a victor speed controller not a jag. If you experience random lock up remove the locking pins.
Unread 16-01-2011, 15:45
ttldomination's Avatar
Sunny
Turns out that the output shaft of the couplers that come with the kit are not 8 mm like the Andy Mark hubs, but instead, they are about 16 mm, or about .63". Would it be wise to take a .625" AM hub and sand out the inside a bit to make it fit on the shaft?
1648: 2013-2014
5283: 2015
Unread 24-01-2011, 09:04
yara92's Avatar
yara92 yara92 is offline
M.Fawdah Mechanical engineering
AKA: Mohamed
FRC #1946 (Mechka Monster)
Team Role: RoboCoach
yara92 will become famous soon enoughyara92 will become famous soon enough
Can you plese send me the cad for this photo
TEAM 1946-Tamra
Unread 25-01-2011, 17:10
clayman's Avatar
clayman clayman is offline
AKA: Clayton
FRC #3175 (Knight Vision)
clayman is an unknown quantity at this point
The CAD for those custom sprockets would also help our team a lot (we currently have no CAD skill).
Unread 25-01-2011, 17:54
artdutra04's Avatar
Attached is a STEP file of the sprocket I machined in the photos above. All I did was download a regular sprocket model from McMaster-Carr (they have CAD models for most of their hardware (screws, nuts, shoulder bolts, sprockets, etc) on their website), use calipers to measure the metric output "spline" of the Denso motor, draw it on the part, and extrude cut it.
To machine it was a four step process. The first thing I had to do was machine a fixture plate out of 6061 aluminum. Then I machined about 90% of the sprocket features onto the 1/2" 7075 aluminum raw material. Then I took that part out, bolted it to the fixture plate upside down, and machined the sprocket teeth into it. The last step is to use a lathe or hand file to bevel the teeth.
There is nothing in this CAD model to keep the sprocket on the shaft of the motor or to support it for cantilevered loads. In the second photo I previously posted, our solution was to machine a custom bushing out of Delrin to both support the shaft and to keep the sprocket laterally in place on the shaft.
Art Dutra IV
世上无难事,只怕有心人.
Unread 27-01-2011, 08:27
yara92's Avatar
AKA: Mohamed
My team 1946 thank you for your help
TEAM 1946-Tamra
Unread 03-02-2011, 07:23
Steve Compton Steve Compton is offline
Project Manager, Mentor
FRC #1391
Steve Compton is a splendid one to beholdSteve Compton is a splendid one to beholdSteve Compton is a splendid one to beholdSteve Compton is a splendid one to beholdSteve Compton is a splendid one to beholdSteve Compton is a splendid one to behold
opps - there it is, thanks!
Unread 03-02-2011, 07:21
FRC #1391
Hey Arthur, Nice work! Do you have any kind of CAD file you could share?
Unread 23-02-2011, 16:57
yara92's Avatar
AKA: Mohamed
Is These chain #25 Or #35 series
the next quation do you have base technical diagram
TEAM 1946-Tamra
Unread 23-02-2011, 18:07
clayman's Avatar
AKA: Clayton
It's for #35 chain, and the diagram is already attached on my previous post.
Unread 24-02-2011, 08:15
yara92's Avatar
AKA: Mohamed
Yes, I meant the sheet metal
TEAM 1946-Tamra
Unread 22-03-2011, 12:06
CordovaRover CordovaRover is offline
FRC #3327
CordovaRover is an unknown quantity at this point
Lightbulb Re: usage of denso window motor
We used this motor this weekend at the peachtree regional and had no success with it. Needless to say we didn't use a sprock. One of our sponors is willing to machine the sprocket for this part if we had it in a CAD file. Can you share the file you have with use so that we may have this part made for our next regional in Knoxville?
