Go to Post I am surprised at the relative conservative capability you described on our 2006 machine. As for the 2007 machine, in anticipation of an aquatic game, we have completed a robot that "walks on water" and are well along with one that can "part the sea". - Bill Beatty [more]
Unread 14-01-2011, 22:04
Biolore Biolore is offline
Lead Programmer
AKA: Josh
FRC #3597 (Robo-Rangers)
Biolore is infamous around these partsBiolore is infamous around these parts
Jaguars
So, my team wants to use jaguars, and I'm not sure what it is that I need to do in the programming to make them work with CAN. I looked at the sample VI, and I'm not sure what to do from there.
Unread 15-01-2011, 00:33
SuperS_5's Avatar
SuperS_5 SuperS_5 is offline
[Certified LabVIEW Developer]
FRC #1219
SuperS_5 will become famous soon enoughSuperS_5 will become famous soon enough
Re: Jaguars
I am still learning the framework of FRC, so hopefully I get this right. The default code should allow you to drive when 2 of jaguars are plugged into pwm1 and pwm2. This is controlled via joystick 1. (arcade drive.)
Edit: If you need to use CAN instead of pwm, then replace the open function in the begin.vi. Replace the "Drive Open 2 motor" with the polymorphic version off of the palette. Then you can choose to use the CAN version.
Mike B
Unread 15-01-2011, 13:11
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Re: Jaguars
Make sure to configure and enable the motors if you use them in Speed, Position, or Current mode.
-- Marshal Horn
