Go to Post Our robot throws custom $5.50 FIRST Frisbees at a rate of 75 discs per minute and a speed of ~32 feet per second. It costs over $80 to feed our robot for 12 seconds. - Woolly [more]
Unread 15-01-2011, 00:14
rp181 rp181 is offline
FRC #0662
rp181 is an unknown quantity at this point
RAM
Is it possible for Netbeans to write the program to RAM instead of re-deploying and writing to flash every single time?
Unread 15-01-2011, 00:29
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: RAM
RAM of the computer? No, the code runs on the robot not the computer. Even if you try writing straight to RAM of the cRio, what is the point? You are still transferring the data over the network to the cRio.
Unread 15-01-2011, 01:19
sjspry sjspry is offline
FRC #1984
sjspry has a spectacular aura aboutsjspry has a spectacular aura aboutsjspry has a spectacular aura about
Re: RAM
Well, I think this is assuming writing to flash causes it to reboot.
If you really don't like the required reboot each time, you could try RobotPy -- not sure how developed it is, though.
Unread 16-01-2011, 22:55
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: RAM
Currently the Java VM and debugging server does not support running a Java program out of RAM. The only way to run it is to deploy and reboot as you would when preparing for competition in C++ or LabVIEW.
-Joe
