Go to Post Welcome to the imperfect world of design! - Joe Johnson [more]
Unread 17-12-2010, 08:32
dmitch's Avatar
dmitch dmitch is offline
Chief Head Electrical Guy
AKA: Daniel Mitchell
FRC #1997 (Stag Robotics)
dmitch is a jewel in the roughdmitch is a jewel in the roughdmitch is a jewel in the roughdmitch is a jewel in the rough
Re: Code Problems
Thank You those diagrams are amazingly helpful! I'll be able to let you know if I need help with anything else after next wednesday.
Unread 05-01-2011, 21:02
dmitch's Avatar
Re: Code Problems
We have completely rewired our robot and it will turn on and thats as far as it will go. I need help with the ethernet cable wiring. The situation is as follows:
When we connect an ethernet cable from the laptop to the wireless router, and another one from the bridge to the cRIO, we recieve no robot communication but the ethernet and radio signals on the driver station are both green and the light on the 1st ethernet slot on the cRIO is lit up.
However, when we tether the ethernet cable, (directly from the laptop to the cRIO) we get the same green radio and ethernet signals but the light on the cRIO slot does not light up.
That probably didn't make sense so i've put together some diagrams that might make a little more sense, they are attached.
This probably isn't really clear but if you have any quesions please ask thank you. I am confused and my coach is not that familiar with the wiring on our robot. Any help would be great.
ID:	9576  Click image for larger version
Name:	Driver Station.jpg
Unread 05-01-2011, 21:21
mattiej's Avatar
mattiej mattiej is offline
Programmer Guy
FRC #3413 (Mad Cows)
mattiej is an unknown quantity at this point
Re: Code Problems
1st: This may be a little simple and looking at your problem probably not the solution, but have you tried using a different Ethernet cable? It just may be you have a bad cable.
2nd: I don't know if you did it just for the picture or what, but are all the modules in for the cRio? In my experience it is generally bad to take them out.
3rd: Try to reset the bridge. It may just be a "frazzled up" in there and need some tuning.
4th: This one seems like the most likely one to me. What did you put as the ip address for your robot? It should be 10.xx.yy.2 , XX and YY being your team number (ex XXYY=3413).
5th: Read through the posts before. Some of those may be it too (router encryption being a big one)
Hope this helps!
Man pretending to be interested: "So how does this robot of yours work?"
Me tired of man pretending to be interested: "Magic. And Purple Yetis."
Unread 06-01-2011, 07:30
Re: Code Problems
Can you say crossover ethernet cable?
Unread 06-01-2011, 07:41
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Re: Code Problems
The fact that the Status light on the cRio stays on indicates a problem there. Check out these Troubleshooting documents http://www.team358.org/files/program...olSystem2009-/
You might have to re-image the cRio.
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
Unread 06-01-2011, 08:40
dmitch's Avatar
Re: Code Problems
All you have to do for this is just input the team number into the text box on the driver station, correct? If so, then I have done this. However, I waould like to make sure there isn't more to it.
Unread 06-01-2011, 13:11
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Re: Code Problems
There sure is.
You can change the cRIO IP address with the re-imaging tool.
(You don't even need to reformat the cRIO to do this)
-- Marshal Horn
Unread 13-01-2011, 13:29
Frenchie461's Avatar
Frenchie461 Frenchie461 is offline
iScout
AKA: Brian, Frenchie, or that guy
Team Role: CAD
Frenchie461 is a jewel in the roughFrenchie461 is a jewel in the roughFrenchie461 is a jewel in the roughFrenchie461 is a jewel in the rough
Re: Code Problems
Ok sorry. First of all, it is coded in LabView.
Well there's your problem
"As a general rule, the most successful man in life is the man who has the best information." - Benjamin Disraeli (1804-81)
Unread 14-01-2011, 20:31
dmitch's Avatar
Re: Code Problems
we got a new cRIO for this year and we tried it in our old robot just to see what would happen. We weren't getting comms wirelessly so we tethered. But both tethered and wireless gave us the same problem: the ethernet and ds radio lights are always green. however, we cant get the bridge light to go on no matter what and so we have no robot comms. the status light on the cRIO is blinking the whole time. We are going to look at the cRIO light indicators tonight but any other ideas are welcome thank you.
Unread 15-01-2011, 08:42
Re: Code Problems
...the ethernet and ds radio lights are always green. however, we cant get the bridge light to go on no matter what and so we have no robot comms...
Have you reconfigured your wireless bridge since it was used in competition? It was set up with a security code at that time. You need to follow the instructions to connect to it using a web browser and reset the security to "none".
Unread 15-01-2011, 09:58
dmitch's Avatar
Re: Code Problems
How do you reconfigure the wireless bridge?
Problems Combining Camera Code and Driving Code cmurdoch Programming 20 10-02-2007 16:34
Problems integrating CMUCAM code and IFI Default Code Windward Programming 2 06-02-2007 16:48
Problems when combine ADC code && camera code nirhaim1942 Programming 1 24-01-2007 06:58
problems using gyro/adc code with camera default code tanstaafl Programming 7 22-01-2006 23:09
Labview problems and code problems ajsetter Programming 25 18-01-2006 17:07
