Go to Post I am a firm believer that there is no model that can be transplanted/copied from one team to another and have the same level of success. There just isn't a formula for it. The mindset you should have is: "I know I have made a positive impact on my community". - tim-tim [more]
Unread 14-01-2011, 20:22
mariak37 mariak37 is offline
FRC #0935 (RaileRobotics)
mariak37 is an unknown quantity at this point
Unhappy Imaging Help!
We started reimaging the cRIO and the Classmate today, and ran into problems with both. When trying to reimage the Classmate, we followed the instructions here:
http://www.usfirst.org/uploadedFiles...tion_Rev_A.pdf
but got stuck after step 5 in Reimage the Classmate. Although we selected the USB device "Generic," it did not ask if we were sure we wanted to do this, and the Classmate simply proceeded to turn on as usual without loading CTL Autoinstaller. We are using a 2010 Classmate.
When we tried to image the cRIO, we used the instructions here:
http://www.usfirst.org/uploadedFiles...cRIO_Rev_A.pdf, but when asked to select the most recent FRC_2011_xx.zip image file, the Select Image list included only FRC_2010_v20.zip. We have downloaded and installed the Utilities update, the Driver Station update, and the LabView update.
Thanks so much!
Maria
Unread 14-01-2011, 21:49
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
Re: Imaging Help!
I got stuck on this too and simply selected the USB device above that one (I forget the precise name, and don't have a Classmate at hand - however there were only two USB devices) and it worked fine.
You can't damage your computer by temporarily changing the boot order, so no worries.
Unread 14-01-2011, 22:08
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
Re: Imaging Help!
When I re-imaged the classmate, when I accessed the boot menu I believe I had to select the USB FILEDISK or the 2nd option under the 16GB SSD's option.
You should see the windows 7 installer load(Windows is loading files...") then the CTL Autoinstaller should open a command prompt and run.
Unread 15-01-2011, 09:34
Re: Imaging Help!
Ok, I tried choosing the other USB option and it still just boots straight to the driver station without any installer appearing.
And, any ideas for the cRIO?
Unread 15-01-2011, 10:05
Zach O's Avatar
Zach O Zach O is offline
Building an iOS app @ glacial speed
AKA: @FRCZach
Zach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond repute
Re: Imaging Help!
I'm also having issues imaging our classmate. The installer from the USB completes just fine, but at boot it'll crash when Windows is loading files. Has anyone else had this issue?
Edit: The classmate will crash when it gets to loading CLASSPNP.sys. For others having this issue, there's a very detailed post on the USFirst Forums, and hopefully it'll get fixed. If anyone has that file, would I be able to boot with a Linux Live USB and replace it myself?
Follow me twitter dot com slash frc zach
Unread 15-01-2011, 11:56
Re: Imaging Help!
Update: We rebooted our computer and the cRIO and the 2011 image appeared, so that was successful, but we still can't get the installer to show up on the Classmate.
Unread 16-01-2011, 15:19
jteadore jteadore is offline
AKA: Jack Teadore
FRC #1676 (Pascack Pioneers)
jteadore is just really nicejteadore is just really nicejteadore is just really nicejteadore is just really nice
Re: Imaging Help!
I am having the same issue as Zach. I have tried to load the image 4 times and the classmate crashes when I try to boot it. The installer says it was successful but now I can't boot. Any ideas?
Jack
Unread 16-01-2011, 21:03
linkhyrule5 linkhyrule5 is offline
FRC #1072
linkhyrule5 is an unknown quantity at this point
Re: Imaging Help!
Heya. I'm also having problems finding the FRC_2011_xx.zip file. Rebooting doesn't work, nor does reimaging - in fact, when we reimaged LabVIEW disappeared entirely, we're going to try a network install later tonight. Any ideas?
Unread 16-01-2011, 21:18
Re: Imaging Help!
LabVIEW isn't part of the image, so it will disappear when you use the stick.
You then have to install
  1. The new LabVIEW
  2. The LabVIEW update
  3. The Utilities Update
  4. The Driver Station Update
P.S.
If you plan on installing LabVIEW or any of the other programming environments, be sure to read this before using the USB Image Stick.
The necessary fix to the stick is here.
Unread 16-01-2011, 22:54
FRC #1072
Re: Imaging Help!
Excellent, I'll try that now. Thanks!
