Go to Post A robot with hands would be cool! - Koko Ed [more]
Unread 14-01-2011, 14:24
wdell wdell is offline
AKA: William Dell
FRC #3999 (Shadetree Mechanics)
wdell has a spectacular aura aboutwdell has a spectacular aura about
Problem sending messages to Driver Station LCD
Every time I try to send a message to the LCD I get a NullPointerException, no matter what I try or who's code I copy. If it hits the line
DriverStationLCD.getInstance().println(DriverStationLCD.Line.kMain6, 1, msg);
it throws an exception. What am I doing wrong?
Thanks!
Unread 14-01-2011, 18:05
ArchVince's Avatar
ArchVince ArchVince is offline
FRC #1290 (Si Se Puede)
ArchVince will become famous soon enough
Re: Problem sending messages to Driver Station LCD
Ah, the LCD. I'm pretty sure that you just forgot an import.
Did you import BOTH of these?
PHP Code:
import edu.wpi.first.wpilibj.DriverStationLCD;
import edu.wpi.first.wpilibj.DriverStationLCD.Line
If so...In my code I always use
PHP Code:
Line.kUser6
instead of
PHP Code:
DriverStationLCD.Line.kUser6
but that probably wouldn't make a difference.
Also, make sure you update the LCD. You won't see any output otherwise.
PETA wants your help finding Schrödinger.
Unread 14-01-2011, 19:16
rrossbach rrossbach is offline
AKA: Ron R
FRC #2607 (RoboVikings)
rrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to behold
Thanks!
Please post the exception you're getting (including the stack trace) and we can try to help
- Ron
Team #2607 controls mentor
FIRST Mid-Atlantic Volunteer
FRC Team #2607 Mentor
Unread 15-01-2011, 11:46
AKA: William Dell
ArchVince's suggestion seems to have worked. Weird, since I'm pretty sure I tried that once. Must have had the syntax wrong.
Thanks for all the help!
