Go to Post So let me get this straight. We'll have 6 hours to re-build an entirely new robot that took us 6 weeks originally to make. - [more]
Unread 15-01-2011, 11:29
oliveryasuna oliveryasuna is offline
FRC #2076
oliveryasuna is an unknown quantity at this point
Configuring the cRIO?
Okay, so I am trying to reconfigure the cRIO so we can deploy our LabVIEW project onto the robot, and have it stay there.
When I try to format the controller I get this error:
"The imaging tool has detected that you have a CAN Plugin enabled and you have an old image installed. Your CompactRIO would hang when trying to reboot. Please remove the CAN plugin from the StartupDlls line in ni-rt.ini and then manually reboot your CompactRIO before trying again."
Can anyone help? Thanks!
Unread 15-01-2011, 12:01
chadbarbe1 chadbarbe1 is offline
AKA: Chad Barbe
FRC #1450 (XQ Robitx)
chadbarbe1 is an unknown quantity at this point
Re: Configuring the cRIO?
I'm having the same exact problem! Please help! I'll post a solution if i find one. Team 1450.
Unread 15-01-2011, 12:14
AKA: Chad Barbe
SOLUTION
Hey, i was able to get around this problem by following this procedure:
1) Turn OFF power to the cRIO
2) Turn the safe mode switch on the cRIO to the ON position.
3) Turn ON power to the cRIO
4) Open the cRIO imaging tool
5) Check the reformat checkbox in the imaging tool
6) Press the Apply button in the imaging tool
7) When the imaging tool pops up a dialog box stating that the cRIO is in safemode, press the button that allows it to continue reformatting
8) It should complete the imaging succesfully
9) Turn OFF power to the cRIO
10) Turn the safe mode switch on the cRIO to the OFF position
11) Turn ON power to the cRIO
12) In the imaging tool, Select the language you want to use (java/c++/labview), re-enter your device name, re-enter your team number
13) Select apply in the imaging tool
14) The cRIO should now successfully re-image.
I think at this point you will NOT have the CAN driver installed. I have not gotten to adding the can driver yet :-)
Unread 15-01-2011, 12:20
FRC #2076
Thanks...
I'll try once we finish fastening the components to the board.
I'll report back!
Unread 15-01-2011, 13:33
FRC #2076
Works thanks!
