Go to Post It's good to learn from experience. It's better to learn from somebody else's experience. - Jay TenBrink [more]
Unread 15-01-2011, 11:57
SudoSammich SudoSammich is offline
A pretty big deal...
AKA: Corey
FRC #0514 (Entropy)
SudoSammich is an unknown quantity at this point
Holonomic Control System
For the first time our team is experimenting with holonomic drive (4 omnis placed at 45 degree angles relative to the frame) and it has fallen to me to code the movement. I have a system in place, but it came to my attention after the initial code was written that different people have different opinions as to how the joystick movements should coorelate to robot movement. As such I'm reaching out to teams who have done this in the past...how'd you guys do it?
At the moment we've got a two joystick design. One stick changes position but not orientation. The robot maintains "front" while moving in whatever direction the joystick tells it to. The second stick controls spin while maintaining position (they won't mix at the moment). This was the first control method that came to mind for me since it allows us to make use of all three degrees of freedom to the greatest extent, but our coach believes that it won't be natural after our years of straight drivetrains.
The other suggested method of control is one sticck that drives much as arcade has in the past, but accompanied by a second stick for strafing to take advantage of our added range of motion. Our coach thinks this will be more natural as a transition, but I don't think it has the same potential since we won't be able to strafe will moving forward.
So for teams who've been successful in the past, how did yours move? Did you find any particular strengths or weaknesses in the control system? Features you wished you'd had? Thanks in advance for the help!
Unread 15-01-2011, 12:36
Re: Holonomic Control System
Some of the more popular driver interfaces for omni & mecanum are:
1) 3-axis joystick. Y controls fwd/rev, X controls strafe, Z (twist axis) controls rotation.
2) Halo. 2 2-axis joysticks. Y1 controls fwd/rev, X1 controls strafe, X2 controls rotation.
3) Arcade plus strafe. 2 2-axis joysticks. Y1 controls fwd/rev, X1 controls rotation, X2 controls strafe.
I'm trying to make sense out of the above. Did you add extra code to purposely zero-out the first joystick when the second one is giving a command (or vice versa)? If so, why did you think that was necessary?
Unread 15-01-2011, 12:38
brianc217's Avatar
brianc217 brianc217 is offline
None #1153
brianc217 is an unknown quantity at this point
When we did it in the past (not for competition) we programmed it the first way you said, with one joystick that controls movement and the other to control rotation. This is actually very intuitive since which ever way you move the joystick, that's the direction the robot will move in. Driver's should adapt to the new control method quite easily.
http://walpolerobotics.org
Unread 15-01-2011, 12:39
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
My personal favorite from the little I've played with Omni-Drive Prototypes is Solution 1. It's probably the easiest and most straight forward way to team someone how to drive and Omni-Drive.
Solution 2 also works extremely well - especially if you've got a bunch of gamers on your team.
-Dustin Benedict
Unread 15-01-2011, 12:42
Jester Jester is offline
Labview Maniac
AKA: Cody Ripley
FRC #3144 (Krypto-Knights)
Jester is an unknown quantity at this point
This year our team is going with a 3-axis joystick, with a twist handle. Logitech sells these for around $30. We got ours at best buy.
Chris is me's Avatar
AKA: Pinecone
Solution 1 (3 axis) is somewhat difficult to use because you may find yourself twisting the joystick slightly during normal operation - the "twist" motion isn't too intuitive for me personally.
Solution 2 (one stick for motion one for reorientation) is my personal favorite.
With all control systems, the number one rule is driver preference. What they feel best with is what they get.
Unread 15-01-2011, 12:52
Ditto what Chris said about #1 and #2 and driver preference.
Since this is your first experience with holonomic, I hesitate to bring this up, but some have found that using the gyro as a fixed-angle reference to provide "field-centric" control (sometimes aka "driver-centric control") provides a superior driver experience with a quicker learning curve.
Unread 15-01-2011, 12:56
Thxe Thxe is offline
FRC #2535
Thxe is an unknown quantity at this point
We used mecanum last year which is pretty much the same from a control point of view. We tried both a single 3-axis joystick and 2 dual axis. We ended up going with 2 dual axis, using one for position control, and one for rotation because that was what our driver prefered, I personally liked the 3 axis better. So I would recommend trying both and just seeing what feels more natural, if your code is writen well, it should be trivial to change.
Also, I would STRONGLY recommend that you look into using a gyro to compensate for robot rotation. Basicly, when you push the movement stick forward, the robot knows how it is oriented and will always move away from you. Likewise, when you move the stick left, it will always go left relative to the control station. This takes just a few minutes to get used to, and is extremely natural after that. If you go with this it is very important to have a button that turns it off also because sometimes the gyro gets messed up.
Unread 15-01-2011, 13:13
I agree with the button, but for a different reason. When the robot is very close to and pointing straight at an object that you want to drive up to, it might in some cases be more intuitive and accurate to push the joystick straight forward.
As for the gyro losing calibration, I suggest a second button you can use to re-calibrate the gyro. Rotate the robot to the zero degree orientation and momentarily press the button to tell the gyro "here, this is zero degrees".
Unread 15-01-2011, 13:47
MotorHead's Avatar
MotorHead MotorHead is offline
Programming Mentor
AKA: Jeff Beltramo
FRC #1922 (OZ-Ram)
MotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to behold
We ran mecanum last year as well and very pleased with it. As stated above, solution #1 is what we went with. Early there was a problem with inadvertent spinning of the robot, so we programmed a deadband to avoid spurious rotations. We also found we had to limit the rate of rotation. If we spun at max speed, this is when gyro error would creep in. I forget the response limit of the gyro, but it was obvious we were exceeding it. I would also concur with adding switches (joystick or other hardware) that allow re-zeroing and canceling gyro compensation completely. Drivers didn't use it often, but it did prove convenient a few times.
Jeff Beltramo
Team #1922
Concord, New Hampshire
Unread 16-01-2011, 10:07
AKA: Corey
FRC #0514 (Entropy)
I wasn't entirely sure how it would mix. I programmed it in the method that I first came up with, which consisted of converting the joystick inputs to a polar coordinate scale (rotated 45 degrees) and mapped each set of motors across from one another to either the X or Y coordinate of the point (respectively). This doesn't exactly lead to an easy blend with spinning as far as I can tell. While it's something I'll probably try to tackle later, it's not done YET.
I saw a system similar to that several years ago with swerve drive actually. We're tossing on a gyro for the camera anyway, so I don't see any reason we wouldn't at least attempt that system if you say your drivers were successful with it.
And thanks all for the responses, I've been thinking CD was down for a few days now when my Droid wouldn't access it XD.
Unread 16-01-2011, 11:38
SudoSammich replied:
The drivetrain you described in your original post (4 omnis placed at 45 degree angles relative to the frame) is holonomic, which means it can perform fore/aft (Y), right/left (X), and rotate (Z) motion simultaneously, if the inverse kinematic calculation for wheel speeds is done correctly.
You don't have to re-invent the wheel (sorry for the pun) if you don't want to. The FRC-provided software development environment contains library functions for the omni drive you described. In LabVIEW for example, using the Cartesian Holonomic vi, all you have to do is wire your Y, X, and Rotate inputs into the vi, and it does all the math. If you have a gyro, there is an input on the vi for that too, so you can have field-centric control.
Unread 16-01-2011, 11:50
AKA: Corey
FRC #0514 (Entropy)
I didn't set out to re-invent the wheel, but it came to that after a small series of events. Basically, our cRio is stuck on last year's bot, so we're using the '07 robot controller and player station mounted to a piece of plywood. As such, I'm writing in C, not LabVIEW (our normal programming language at this point is Java anyway, but I assume there's a class for that as well). And I'm sure it's capable of two dimensional movement while spinning, I just haven't put forth the energy into performing those calculations yet. Good to know that there's a class waiting for me when we transition to this year's real bot though.
Unread 16-01-2011, 12:04
Jogo Jogo is offline
FRC #0353 (Pobots)
Jogo is on a distinguished road
Ether--
According to the inverse kinematics solution (http://www.simbotics.org/files/first...irectional.pdf), The wheel speeds are also functions of the distance between the wheels and the center of the robot...the labview VI doesn't seem to account for this. Any suggestions? I'm assuming all the axis probably will need to be scaled anyway.
Unread 16-01-2011, 12:13
Originally Posted by Jogo View Post
Ether--
You are correct, but the only degree of freedom that is affected by the wheelbase and trackwidth dimensions as far as the inverse kinematic calculation is concerned is the "rotate" command, and this can safely be tuned empirically to a suitable value (by multiplying the joystick rotate command by a scale factor, for example).
I posted a paper (see link below) which goes into more technical detail showing how the wheel positions affect the calculations, if you are interested. It even covers cases where the wheels are not located equidistant from the chosen centerpoint.
http://www.chiefdelphi.com/media/papers/download/2722
[edit] the above-referenced paper specifically deals with mecanum wheels, but the same principles can be used to analyze holonomic [/edit]
