Go to Post Oh, and a general guiding principle: Don't be stupid. - Billfred [more]
Unread 15-01-2011, 12:53
Team 1574's Avatar
Team 1574 Team 1574 is offline
FRC #1574
Team 1574 is an unknown quantity at this point
Ftc Battery dimensions, weight and ampere.
Hello Chiefdelphi!
Our team will get the Ftc kit only in two weeks from today so we have to know what are the dimensions of the battery, what is the weight and what is Ampere (Si) of the Ftc Battery!
Thanks a lot!
MisCar 1574
Unread 15-01-2011, 15:59
Frenchie461's Avatar
Frenchie461 Frenchie461 is offline
iScout
AKA: Brian, Frenchie, or that guy
Team Role: CAD
Frenchie461 is a jewel in the roughFrenchie461 is a jewel in the roughFrenchie461 is a jewel in the roughFrenchie461 is a jewel in the rough
Re: Ftc Battery dimensions, weight and ampere.
12V@3 amps
and it's 4.5" long X 1.5" wide X 1.75" tall
"As a general rule, the most successful man in life is the man who has the best information." - Benjamin Disraeli (1804-81)
Unread 15-01-2011, 16:16
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
The battery will produce quite a bit more than 3 amps. The capacity rating is 3 amp hours. There is a 20 amp fuse on the wire connector that is part of the battery.
http://shop.pitsco.com/store/detail.aspx?ID=5476&bhjs=0
Unread 16-01-2011, 11:27
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Anyone care to guess whether the entire wiring harness including that fuse and holder are required to be on the minibot? With the emphasis on weight being what it is certain to become, saving an ounce here and there could mean all the d2x/dt2 you need to win. <R92> makes no mention of fuse or wiring harness, but it does mention the stock number explicitly. Q&A time I suppose.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 16-01-2011, 11:44
MrForbes's Avatar
AKA: Jim
I'd be shocked if they'd let us run the battery without the fuse/connector assembly attached. And it's $50 plus shipping to replace the battery assembly if you cut it off.....just saying...
