Go to Post Chairman's Award is not about building the robot. Every team builds a robot. - Retired Starman [more]
Unread 15-01-2011, 00:18
Creator Mat Creator Mat is offline
FRC #2338 (Gear it Forward)
Creator Mat is a jewel in the roughCreator Mat is a jewel in the roughCreator Mat is a jewel in the roughCreator Mat is a jewel in the rough
Definition of a Aluminum Sheet
In the rules for the mini-bots it says that Aluminum sheet is allowed. So what is the definition of a Aluminum sheet. 1" thick, 1/2" thick, or 1/4" thick piece of aluminum? Or could we get a 12" x 12" x 12" block of aluminum machine it out and call it a "sheet"? Where does a sheet of aluminum stop being a sheet and becomes a block?
2010 Midwest Spirit award
2010 Midwest Quarterfinalists
2010 Wisconsin Quarterfinalists
2009 Midwest Finalists
2009 Wisconsin Quarterfinalists
2008 Midwest Rookie AllStars
Unread 15-01-2011, 00:27
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Definition of a Aluminum Sheet
wikipedia is always right...it says up to 1/4 inch
http://en.wikipedia.org/wiki/Sheet_metal
sounds good to me
Unread 15-01-2011, 00:51
dtengineering's Avatar
AKA: Jason Brett
I don't believe melting and casting are disallowed by the rules... in previous years we cast and turned wheel hubs, and at least some of the aluminum in those hubs was... in a former life... sheet.
Now, I'd probably get a Q&A ruling on this, as I'd kind of suspect that "sheet" means that it starts as sheet and stays as "sheet"... but it doesn't say so (yet) as far as I know. I'd also be prepared to document the fact that whatever cast component you make started out as sheet.
Perhaps a better way would be to use a CNC machine to cut thin layers of your project from sheet stock and build up your mechanism layer by layer... you could use aircraft grade adhesives to hold the aluminum together and then go back and do a final machining pass to get everything exactly to size.
Jason
Unread 15-01-2011, 01:06
Chris is me's Avatar
AKA: Pinecone
Food for thought: Vex metal was once aluminium sheet.
Unread 15-01-2011, 01:08
DonRotolo's Avatar
Back to humble
FRC #0832
There are some very strong automotive (body repair) adhesives too, probably more readily available and less costly as well.
Unread 15-01-2011, 01:43
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
Jason
Aircraft grade adhesive is not an allowable material, is it?
Unread 15-01-2011, 01:48
foote stepped in
AKA: E. Foote
FRC #0868
I'd say it stops being a sheet when you can no longer bend it with a normal shop setup.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
Unread 15-01-2011, 02:47
Rion Atkinson's Avatar
Rion Atkinson Rion Atkinson is offline
The CAD Guy
Rion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond repute
Now your question is what is a "normal shop set up." Take 148 the past few years. Sheet metal robots, just bent and riveted.
‎‎"I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. -Albert Einstein
Start Something
Email - rionatkinson@gmail.com
Skype - Rion.Atkinson
Unread 15-01-2011, 03:26
sounds good to me
Its right until I change the entry... jk. Thx for the answer i couldn't find my answer on wiki I guess a search of "sheet" doesn't cut it I have to search "sheet metal", who knew?
Unread 15-01-2011, 03:45
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Generally speaking, I've always regarded anything over 1/8" thick as plate. Don't they also allow any aluminum bar stock though?
Unread 15-01-2011, 09:41
MrForbes's Avatar
AKA: Jim
I can bend 1/4" relatively easily in my press, I can bend thicker metal too, but not in very useful ways.
Even if wiki is not always right (that was a little joke) I would say 1/8" is definitely sheet metal, and 3/8" is definitely not sheet metal. So it's somewhere around 1/4" thick that it changes.
Unread 15-01-2011, 10:53
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: Definition of a Aluminum Sheet
ihave always taught the sheet metal was differentiated from plate by having a gauge number. Consulting the engineer's handbook, go to this link for clarification and documentation:
http://www.engineershandbook.com/Tables/gauge2.htm
Notice the difference between ferrous and non- ferrous metals.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 15-01-2011, 12:34
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Isn't it still?
Unread 15-01-2011, 12:57
Bob Steele's Avatar
AKA: Bob Steele
What Vex metal are we talking about here?
Most of the metal in my VEX kits is steel
The FTC metal is aluminum...
Has VEX changed over to aluminum?
I have some VERY expensive aluminum parts that I got a few years ago from VEX that are aluminum... that is the only aluminum I see on the VEX product site. 99.95 for an aluminum chassis kit... Do they have sheet?
just curious
