Go to Post However I do wish to reassure people that the judges did not just fall off the back of a turnip truck... - dtengineering [more]
Unread 14-01-2011, 22:22
RMS11's Avatar
RMS11 RMS11 is offline
Safety!!!!
AKA: Rick
FRC #2415 (WiredCats)
Team Role: Driver
RMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to behold
Send a message via AIM to RMS11
2415 Roller Gripper Prototype Video
We got this put together yesterday to test some dimensions for the gripper before we send off the final sheet metal parts to our machine shop sponsor. Let me know if you have any questions, ect.
http://www.youtube.com/watch?v=oaUkxsGIFWk
2009 Peachtree Regional Champs
2009 Palmetto Regional Champs
2008 Peachtree Rookie All Star and Rookie Highest Seed
Unread 14-01-2011, 22:29
Stephen of REX's Avatar
Stephen of REX Stephen of REX is offline
FRC #1727 (REX)
Stephen of REX is an unknown quantity at this point
Re: 2415 Roller Gripper Prototype Video
Nice.
Go REX!!!
Chris is me's Avatar
AKA: Pinecone
Does it grab the small part of the triangle?
Is it spring loaded?
Unread 14-01-2011, 22:33
RMS11's Avatar
Safety!!!!
AKA: Rick
Team Role: Driver
Yes it does, we just did not have that object in the shop at the time. We found the wider the roller is, it can suck the corners in nice and deep. It is not spring loaded. We have a lot of compression, but the urethane belting adds a spring-like element when it stretches.
Unread 14-01-2011, 22:36
FRC #1727 (REX)
Sounds like you can't handle deflated tubes though. You should take some air out of one and see what happens.
Go REX!!!
Unread 14-01-2011, 22:39
RMS11's Avatar
Safety!!!!
AKA: Rick
Team Role: Driver
The gripper compresses the tubes down anywhere from 2-3 inches. The rules state that all the tubes will be kept from 7-8" in diameter. With the tubes at any inflation in this range, our gripper can handle them.
Unread 14-01-2011, 22:41
AKA: Pinecone
Our triangle piece is as shallow as 5.5 inches in the middle fully inflated. Are the specs going to be kept that tight at competition?
Unread 14-01-2011, 22:43
RMS11's Avatar
Safety!!!!
AKA: Rick
Team Role: Driver
This design compresses all objects to well below 5", and handles the triangles with no noticeable difference as the other two shapes. Also, the two belts run at approaching angles, compressing the shapes more as they are pulled in.
Unread 15-01-2011, 13:15
ttldomination's Avatar
Sunny
I guess Sean wasn't able to convince yall to go over to wood.
1648: 2013-2014
5283: 2015
Unread 15-01-2011, 13:28
Andrew Y.'s Avatar
Andrew Y. Andrew Y. is offline
FunYun
AKA: Andrew Yun
FRC #2415
Andrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud of
santosh, i know we have had our differences, but targeting your old team in a public enviroment is not the route to go. if you have a problem...come talk to me in the publix parking lot @6:00 today. but we need to be done by 8 because thats when the game is. we are sorry it didnt work out with us...
Unread 15-01-2011, 13:45
AKA: Pinecone
Nah, they just do it backwards of most teams. Instead of prototyping with plywood and machining metal for the final version, they make their prototypes out of sheet metal and machine the final robot out of wood.
[/joke post]
Unread 18-01-2011, 10:52
Joining the 900 Meme Team
FRC #0079
The thing would have stopped running. I've done this kind of prototyping for nearly a decade now and never had anyone hurt by a drill "popping off". In fact, using a system with a clutch and that loses power if someone drops it is significantly safer than using a motor with connectors into a battery or with exposed leads as I see quite frequently. Additionally all the gears are encased in a nice plastic shell so they can't catch fingers. Honestly, for prototypes drills are a pretty nice way to test. They have variable speeds, stop really quick, and have a clutch so you probably won't destroy your mechanism if it hits a hard stop. It also probably won't destroy a person if your mechanism hits them before you let go of the trigger.
2415, thanks for sharing. We have a couple roller claw prototypes out of Vex parts but I think I might get busy with a router and some plywood tonight to see if the shape of the back has a large impact.
A few questions:
What is your compression? You say you are compressing to less than 5" thickness. Does the drill seem to be struggling at all?
Have you tried other widths? 5", 7", 9"? Did this have an impact?
Have you tried not having rollers in the middle and instead grabbing from two points on the side?
Have you tried pulling your tubes out by hand both while the motors are running and while they aren't? Perhaps use a cable tied to the piece with a force gauge to measure your grip strength.
Have you tried grabbing at an angle? Both relative to the floor and relative to the tube.
Unread 18-01-2011, 11:17
RMS11's Avatar
Safety!!!!
AKA: Rick
Team Role: Driver
Drill does not seem to struggle at all. We will be using a 550 and a 1:16 banebots transmission.
We were satisfied with this result enough to not try any other amounts of compression. Much less (~6" or greater) would have probably struggled to maintain grip.
Yes. It is effective to an extent (pretty much as long as you are going fairly straight and the roller tries to grab the tube it will work.
We have not measured the grip strength with a force gauge but we do plan to turn off the motors once we have control and rely on the friction of the system (both the gearbox, the chain, and the belt) to hold the tube.
Works just as well, although we plan to be grabbing straight on most of the time as it is easier to line up.
Unread 19-01-2011, 01:51
Carter12s's Avatar
Carter12s Carter12s is offline
Team Cap
FRC #3374 (Robo-Broncs)
Carter12s is just really niceCarter12s is just really niceCarter12s is just really niceCarter12s is just really nice
How well does that keep the tubes from rotating once it has held them. Can it rotate the tubes in place to adjust angle while placing??
Programing is the real way to build a robot.
Unread 19-01-2011, 02:00
RMS11's Avatar
Safety!!!!
AKA: Rick
Team Role: Driver
No, in the final design it will all be powered by 1 motor. We thought it would be too hard to accurately rotate with 2 rollers. Instead, our design rotates the entire claw, giving the same effect and making it easier to fit inside starting dimensions.
