Go to Post The game is as much a competition of strategies as it is of robots. There is never any one "best strategy." If teams choose to use this as their strategy, find one that will beat them. - srjjs [more]
Unread 15-01-2011, 14:23
weinertj's Avatar
weinertj weinertj is offline
Time Lord
AKA: John Weinert
FRC #3131 (Gladiators)
Team Role: Student
weinertj is an unknown quantity at this point
Vaccuum gripper
I haven't been able to find anything on Chief Delphi about this. Any thoughts on using a vaccuum gripper to pick up the game pieces?
Unread 15-01-2011, 14:30
mayde's Avatar
mayde mayde is offline
Team Captain / Pirate Queen
AKA: Mayde Smith
FRC #2865 (Roboteknix)
mayde is on a distinguished road
Send a message via MSN to mayde
Re: Vaccuum gripper
My team briefly considered the possibility, but it seems like it would be expensive to build your own.
furthermore, it would be effective for holding the tubes, but it seems like it would be difficult to position them the right way. i don't know. maybe not so difficult.
how were you planning on building it? would it hold the tube from the top or the sides?
Surprise.
Roboteknix 2865;
2010 Spirit- Portland Autodesk Regional
2011 Safety Captain - Seattle Regional
2012 Team Captain- Cheney (Spokane) Regional
Unread 15-01-2011, 14:36
Re: Vaccuum gripper
Try searching for "vacuum" (one c).
You'll get lots of hits.
Unread 15-01-2011, 16:50
weinertj's Avatar
Time Lord
AKA: John Weinert
Team Role: Student
Re: Vaccuum gripper
Thanks.
Unread 16-01-2011, 11:45
balloons balloons is offline
FRC #0503
balloons is on a distinguished road
Re: Vaccuum gripper
Originally Posted by sdcantrell56 View Post
Look up 1771 and 2415 from the past. Vacuum grippers are far superior to any other variety. Particularly in acquisition and maximum holding power. Doing any other gripper is simply settling for less than the best.
I can only hope that this is a joke.
Unread 16-01-2011, 12:53
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Vaccuum gripper
Agreed, Vacuum may not be a good choice. Test it before committing to it.
Unread 16-01-2011, 13:14
skimoose's Avatar
skimoose skimoose is offline
Parent/Mentor/Engineer
AKA: Arthur Dutra
FRC #0228 (GUS)
Team Role: Electrical
skimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond repute
Re: Vaccuum gripper
I'll agree with Don test before you commit, but we used vacuums on last years robot. They were made from 2.5 gallon shop vacs from Home Depot.
They cost about $25 and we powered them with a FP motor. It was a pretty simple modification. FIRST cut away everything extra except the impeller housing and a little of the flange material for mounting surfaces. The brush mount for the stock ac motor was a perfect fit for the FP motor mount. Then you just needed to turn a shaft on the lathe to mate the FP motor shaft to the vacuum impeller. Here's a picture of the finished modifications. The entire mechanism with hose, mounting hardware, and our final COTS suction cup was under 2 pounds.
I thought this might help if you do want to test vacuum grippers.
2009 CT Regional Motorola Quality Award
2010 VRC Connecticut Championship Winners & Amaze Award
2010 VRC Championship Divisional Energy Award
2010 WPI Regional Winner
2010 WPI Regional Engineering Inspiration Award
2011 WPI Regional Chairman's Award
2012 WPI Regional Finalists
Unread 16-01-2011, 13:36
Re: Vaccuum gripper
Nice.
Do you have any data for that design, such as current draw with and without a piece being held?
Unread 16-01-2011, 13:49
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
Re: Vaccuum gripper
Vacuum grippers are really good picking up objects that have a readily oriented flat surface, and for spherical objects. The biggest challenges you will face with this year's game pieces are orienting the suction cup to get a seal, sealing, and achieving sufficient holding force not to drop them. The holding force is proportional to two things:
  1. The pressure differential between the environment (atmosphere) and inside the suction cup
  2. The area inside the suction cup.
This years game pieces do not lend themselves well to large suction cup area, so you will have to rely on high vacuum. You can't achieve much delta P with a shop vac (we have tried). An ejector type vacuum generator (works off air pressure from the pneumatic system) will generate relatively high vacuum,. but only if you have a tight seal. We were successful in 2008 with a shop vac arrangement because we had a huge area to work with. We were less successful last year because the available area was too small. (that's why we abandoned the vacuum after Peachtree)
I am not saying don't try it! please do, and I hope you are successful. I just want you to be aware of the challenges and available options. If you have any questions (vendors, how-to etc), PM me and I will try to answer.
Former Mentor Team 1771
Former mentor Team 4509
Unread 16-01-2011, 14:10
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Re: Vaccuum gripper
My post was indeed a joke. I would strongly caution against a vacuum this year. If for some reason you still want to pursue a vacuum gripper then Martin is without a doubt the man to get in touch with.
Mentor 2415
