Go to Post The code is hopefully pretty self-documenting, but I haven't had time to comment it (kinda trying to build a robot at the moment). - RyanCahoon [more]
Unread 15-01-2011, 11:56
Pat_Cunningham Pat_Cunningham is offline
FRC #0178
Pat_Cunningham is an unknown quantity at this point
FRC 2011 cRio
I am having problems connecting and imaging my cRio after I apply the 2011 FRC v25 image. Any ideas?
Thanks,
Pat Cunningham
Unread 15-01-2011, 12:38
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
Re: FRC 2011 cRio
Could you please explain the problems in detail? Any error messages? Make sure your network and other components are configured as per the manual.
Unread 15-01-2011, 13:22
FRC #0178
Re: FRC 2011 cRio
I have done all diagnostic things such as different network cards, and different computers, and the only thing that I can think of for the problem is the, 2011 driver station update, the 2011 labview update, or the 2011 v25 crio image update.
Unread 15-01-2011, 14:41
TD912 TD912 is offline
AKA: Chris Leung
FRC #1989 (Viking Robotics)
TD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud of
Re: FRC 2011 cRio
I'm not sure what you're exact problem is, but I do know that if you install the 2011 LabView update over the 2010 software, you will get a bunch of random errors when you try to deploy code.
We forgot to install the full 2011 LabView software first, and everything appeared fine until trying to deploy code for the first time.
If this is the case, uninstall LabView completely (Be sure to select all of the parts in the "Uninstall" window) and reinstall using the 2011 DVD.
Zip-ties, hot glue, and duct tape.
2008 New York City Regional Champions - (41/555/1989)
2009 Brunswick Eruption 8 Finalists - (1989/56/1807)
2010 PARC XIII Champions - (25/341/1989)
Over The Bump
Unread 16-01-2011, 19:45
kennethdharmon2 kennethdharmon2 is offline
FRC #1288
kennethdharmon2 is an unknown quantity at this point
Re: FRC 2011 cRio
TD912, I'm curious, what type of errors were you seeing?
There was this comment in the "Getting_Started_with_the_2011_FRC_Control_System_ Rev_A.pdf"
"If you currently have National Instruments software on your PC, it will not interfere with that installation. However it will install over another version of LabView 8.6."
This led us to believe you didn't need to do an uninstall of LV 8.6, 2010, before installing the 2011 version. So we installed 2011 LabView right over the 2010 version, works fine, can deploy code, but can't seem to successfully set it as startup code. Not sure why. Did you see this issue?
Unread 16-01-2011, 19:48
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: FRC 2011 cRio
Well if this can help: I am able to connect with the 2010 imaged cRio with the 2011 imaged Classmate. I think its the cRio flash that is the problem, not the classmate.
Unread 16-01-2011, 20:03
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: FRC 2011 cRio
Likewise, I ran a 2011 cRio with a 2010 classmate, on 2010 LabVIEW (using the 2011 product key) and the 2011 LabVIEW software update, and everything worked fine.
The LabVIEW update has some errors, because the palette points to the old (empty) files (in vi.lib\Robotics Library) instead of vi.lib\Rock Robotics. The new library has an annoying "Safey Update" feature which will spawn a new thread for each device, and kill the output if you don't update it fast enough (I guess its a fix to the Watchdog, but I honestly liked the Watchdog more). I have found no functional difference in any features (yet).
I did, however, find what might be an FPGA image bug here. It could be me doing something wrong, or it could be a bug in the library, too.
Kettering Motorsports
Unread 17-01-2011, 01:13
jhersh jhersh is offline
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: FRC 2011 cRio
What about the new safety update feature do you find annoying? You can disable the safety update feature and go back to using the watchdog. We left that as a possibility for people who hold your opinion. I am curious as to why you don't like it. Any feedback will help us to improve the interface and functionality.
Thanks,
-Joe
Unread 18-01-2011, 22:38
AKA: Chris Leung
Re: FRC 2011 cRio
We had an installation of LabView 2009 for FTC that hasn't been used much (we have another computer for FTC), and LabView 8.6 for 2010 FRC. Someone accidentally installed a 2011 update, not the full version, over the 2010 version, and whenever code was was ran or deployed we would get a "Microsoft C++ Runtime Error" saying something similar to "The program was called to terminate unexpectedly" and then LabView would crash.
I'm not 100% sure what caused the problem, but uninstalling all versions of LV (2009, 8.6 2010, 8.6 2011) and reinstalling 2011 worked fine.
Over The Bump
