Go to Post Wow! Shipping to Israel?!? It's exciting to have a fan from so far away :D - stens987 [more]
Unread 16-01-2011, 10:34
artbot345 artbot345 is offline
FRC #0931 (Perpetual Chaos)
artbot345 is an unknown quantity at this point
Re: FRC LabVIEW install
Ok when LabVIEW Real-Time 8.6.1 LabVIEW, Real-Time Patch, and NI-RIO start installing the installer exits.
Unread 16-01-2011, 13:54
I had similar problems when I was out of disk space.
Unread 16-01-2011, 15:55
That's not the problem but all of the not installed components give me the NI-VISTA error.
Unread 16-01-2011, 18:43
Should I download and install this? http://joule.ni.com/nidu/cds/view/p/id/2185/lang/en
Unread 16-01-2011, 22:54
mck1117 mck1117 is offline
AKA: Matthew Kennedy
FRC #1294 (Top Gun)
mck1117 is an unknown quantity at this point
I'm having the same problem on a Dell Studio 1458. I have plenty of disk space, and this is what the errors are in the installer:
Unsupported version of NI-VISA detected
A version of NI-VISA that is not supported on this operating system has been detected. You must cancel this installation and uninstall the older version before continuing. Refer to ni.com/vista for more information.
NI-RIO
A version of NI-VISA that is not supported on this operating system has been detected. You must cancel this installation and uninstall the older version before continuing. Visit ni.com/info and enter the Info Code CleanVista for more information.
Unread 17-01-2011, 00:01
SuperS_5's Avatar
SuperS_5 SuperS_5 is offline
[Certified LabVIEW Developer]
FRC #1219
SuperS_5 will become famous soon enoughSuperS_5 will become famous soon enough
Is this a fresh install, or upgrade? Ensure that you are installing with administrator privileges. If you had administrator privileges, you may want to try uninstalling all NI components, and then use the MSIblast program to uninstall anything remaining. (MSIblast from the NI forums) Retry installing after a restart. (Remember to use administrator privileges for uninstalling/reinstalling)
Mike B
Unread 17-01-2011, 01:30
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Are any of you trying to install on Windows 7 Starter? I know some of the drivers are not compatible with Windows 7 Starter.
Unread 17-01-2011, 01:35
FRC #1294 (Top Gun)
Nope. I'm running Windows 7 Ultimate x64.
Unread 17-01-2011, 01:52
FRC #1294 (Top Gun)
After running MSIBlast, still no luck. Running the setup wizard gives the same errors.
Unread 18-01-2011, 11:15
I'll still getting errors too and when I try to install NI-VISA 4.1 I get Unsupported version of NI-VISA detected.
Unread 18-01-2011, 19:17
Carter12s's Avatar
Carter12s Carter12s is offline
FRC #2036 (Black Knights)
Carter12s is just really niceCarter12s is just really niceCarter12s is just really niceCarter12s is just really nice
I am also having a problem. I install Labview and everything appears to work, but when i start Labview it is not FRC edition, and I cannot access the WPI robotics library or the default templates. It appears to me that the FRC Tools are not installing so I try reinstalling them and the re-installation does not work. It cites no error and does not inform me of the failure until the very last step, where it presents the installation report, and tells me that "no software was installed" under any of the categories. I looked in the NI Uninstall/Or Modify application and it shows the FIRST Utilities as an uninstallable option. Has anyone else encountered and error like this? Or does anyone have any advice? I have run the install several times now, and i have completely uninstall-ed everything and started from scratch multiple times.
Computer Specs:
Dell with Winodows 7 Ultimate 64 bit
2 Core Pentium with 2.76 GHz
8 GB of RAM
Programing is the real way to build a robot.
Unread 18-01-2011, 19:36
FRC #1294 (Top Gun)
It seems like your problem is that you need to install the LabVIEW updates, and the FRC 2011 Utilities.
I found a solution to my problem (and artbot's) though:
In the registry, there was a key marking that NI-VISA 3.2 (!!) was installed. I have never had NI-VISA installed before, and I dont know where this came from. It was in HKLM\SOFTWARE\National Instruments\NI-VISA. There was a value named "CurrentVersion", which had its value set to 3.2. I uninstalled all of LabVIEW, removed all of the contents of the key "HKLM\SOFTWARE\National Instruments", reinstalled and it worked.
Unread 18-01-2011, 23:52
Carter12s's Avatar
You are right SIR! Installing the Labview updates cured four separate computers of mine from being unable to recognize the FRC Utilities. I guess the two computers it worked on without the updates were flukes. It seems like the update really does resolve a lot of problems and should be installed whether you think your original install went correctly or not. Thanks for the help!
Unread 19-01-2011, 12:48
How do I get to: "HKLM\SOFTWARE\National Instruments"? I did a C drive search and it did not find any folder named "HKLM".
