Go to Post Don't count out some of the new guys, they will suprise you!! - PMGRACER [more]
Unread 16-01-2011, 11:00
ehlochbr ehlochbr is offline
FRC #2990
ehlochbr is an unknown quantity at this point
WindRiver IO Error - Please Help!
I recently updated all our computers with the new 2011 updates from FIRST. Everything seemed fine until I tried to upload new code to the cRIO. When I did that I got an "IO Error while downloading program to robot."
WindRiver will connect to the robot, I just can't download any new code. Any help would be greatly appreciated. Thanks.
Eric
Unread 17-01-2011, 03:03
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: WindRiver IO Error - Please Help!
Eric
Please be more detailed about exactly what you are clicking on and exactly what the error message is. I haven't seen anything like what you're describing before.
Thanks,
-Joe
Unread 17-01-2011, 11:08
FRC #2990
I'll try but, unfortunately, there isn't much more to tell. I can setup the team network and everything connects as it should (router, driver station, cRIO...etc). I can even connect to the network using WindRiver on my laptop. I just can't download new code to the cRIO.
I'm sure you know that when you want to download new code in WindRiver you select the FIRST drop-down menu at the top of the screen and select "Deploy." When I do that I get an error message screen that says "IO Error while downloading program to robot."
Everything else seems works just fine. I was able to use the "Undeploy" selection so now the cRIO has no code and I can't download anything.
If I can't solve this then I'm afraid I'm going to have to completely uninstall and then reinstall WR to see if that helps, but I really don't want to have to do that. Thanks for looking at this post.
Eric
Unread 17-01-2011, 17:44
Eric
Have you configured your team number and .out file to deploy?
Unread 17-01-2011, 18:59
FRC #2990
I'm not sure. I haven't changed anything from last years settings and it was working fine. Could you please elaborate? Thanks.
Eric
Unread 19-01-2011, 09:49
FRC #2990
I've figured it out. I guess you can't rename the project in WindRiver without it affecting the .out file. Thanks for your help!
