Go to Post Stacking totes on end; Gives you extra height, alas; Topples with a sneeze. - BethMo [more]
Unread 15-01-2011, 12:04
Thee Alchemyst Thee Alchemyst is offline
Columnist/Novelist/Elo Technician
FRC #3461 (Operation PEACCE)
Team Role: Electrical
Thee Alchemyst is on a distinguished road
Difficulty Wiring (Rookie Team) HELP US!
We're having trouble even starting wiring our electrical components, starting with something as simple as the main power distribution board. Is there any place where it offers a breakdown of how to wire the boards, jaguars, etc. that come in the kit of parts?
We found this earlier ( Picture Diagrams ) but as soon as we get to the wiring components, we especially cannot tell how to connect the wires to the distribution board. We got the two big blue connectors, but what's with the rest? HELP!
I've seen some schematics, but they're confusing the heck out of me here with some of the components.
@ Tanis: Brilliant, but we're also having trouble connecting parts to the distribution board. See second paragraph please.... (So no need for repetition.)
Unread 15-01-2011, 12:18
Bryan Herbst's Avatar
Bryan Herbst Bryan Herbst is offline
AKA: Bryan
FRC #2052 (KnightKrawler)
Bryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond repute
Re: Difficulty Wiring (Rookie Team) HELP US!
Check out the 2010 control system manual.
There you will find wiring diagrams and more details on where everything goes.
Team 2052- Knightkrawler
Mentor and volunteer
Unread 16-01-2011, 11:27
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
The Power Distribution Board (PDB) is primarily wired with the use of Wago connectors, which to my knowledge has never been explained in a manual. For the connections along the long sides of the PDB, you have a small slot right above a round hole. To secure a wire in that hole, put a screwdriver in that slot and lever it either up or down, I can't remember which, and while it's levered, insert the wire. Then pull the screwdriver out.
These PDB connections make use of strong springs to secure the wires, which by default block the hole. Levering a screwdriver in that slot unblocks the hole by raising the spring, and pulling it back out drops the spring back on the wire that you've inserted, securing it in place.
Be sure to use appropriate gauge wire for wiring purposes. Personally, by team uses 6AWG wire for battery - switch - PDB connections, ~10-12AWG for 40A distributions from the PDB, and ~16-18 for 20A-30A distributions from the PDB.
Unread 16-01-2011, 12:05
Cecil's Avatar
Cecil Cecil is online now
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
You should have got a small screwdriver with "WAGO" written on the side. On the power distribution board, there are 2 slots, one on top, and one on bottom per individual connector. put the screwdriver in there as far as it will go while holding it horizontally. Now pull up on the screwdriver. A jaw in the bottom one should open, and you can put the wire in. At this point, you can release the screwdriver.
For the 40 amp breaker slots, the way the power flows is towards the small lightning bolt, meaning if you put a breaker into that slot, that is the one that will be powered. Hope this helps!
I'm right 90% of the time, so why worry about the other 3%?
Unread 16-01-2011, 12:51
DonRotolo's Avatar
Back to humble
FRC #0832
Do NOT "pry" or "lever" with the WAGO tool, you'll break things. You put the tool into the slot and push it in. Your ONLY motion should be pushing, NO PRYING.
See this specific post, follow the link to the presentation, and study the photograph. This will help you understand exactly how to use the WAGO connectors on the PDB correctly.
Unread 16-01-2011, 13:20
RUFINESS's Avatar
RUFINESS RUFINESS is offline
FRC #3244 (Granite City Gear Heads)
RUFINESS is an unknown quantity at this point
Here are this years
Power
and
Data
wiring diagrams for this years robot.
Unread 16-01-2011, 15:00
JohnHorton's Avatar
JohnHorton JohnHorton is offline
Shock Test Dummy
FRC #1100 (Tomahawks)
JohnHorton will become famous soon enough
As for the smaller WAGO connectors, it's the same as the PD board. Just put the tip of a small screwdriver into the slot, and lever down. The connector from the PD board to the cRIO is different, as you have to turn the screws behind the wire slots to open and close the gripper inside.
I had the same problem when I started out. It just takes some trial and error.
The tall guy in the camouflage hat.
John Horton
Unread 16-01-2011, 15:08
jsasaki's Avatar
jsasaki jsasaki is offline
AKA: Jun Sasaki
jsasaki has a spectacular aura aboutjsasaki has a spectacular aura aboutjsasaki has a spectacular aura about
this might help as far as the pdb goes. thanks to oregon first.
