Re: Integrating the Accelerometer
Thanks for the feedback.
As far as encoders...I don't really know how well those will do because we are using mecanum. |
I'm also worried about having the robot correctly oriented so that gyro angle zero is exactly perpendicular to the front of the field. Otherwise, we wouldn't get perfect results.. is this going to be a huge problem for autonomous? |
Also note that the encoder is measuring the wheel rotations, which for mecanum wheels does not directly translate into distance = circumference * rotations. You will have to invert the mecanum control equations to make sense of the 4 wheel position channels. |
It would probably be easier to put encoders on two unpowered omni-wheels that are 90 degrees from each other.
Something similar to http://www.chiefdelphi.com/media/photos/32440 |
