Go to Post Commence the year of the brown out! - Jared Russell [more]
Unread 15-01-2011, 15:27
vinnie's Avatar
vinnie vinnie is offline
FRC #3309 (Friarbots)
vinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond repute
CAN
Hi, my team has decided to use CAN for our Jaguars this year, and when I try to run the Java code that I wrote, the CRio sends an edu.wpi.edu.first.wpilibj.util.UncleanStatusExcept ion: In JaguarCANDriver::sendMessage, fatal status code detected -52010
Please help us Thanks
Unread 16-01-2011, 13:17
drakesword drakesword is offline
AKA: Bryant
FRC #0346 (Robohawks)
drakesword is on a distinguished road
Re: CAN
There are many teams having issues with Java and can. see Technical>Electrical>Can -> Updated Can Issues
Until the issues are fixed there is no can in java.
Unread 18-01-2011, 09:31
AKA: Brad
#0190 ( Gompei and the Herd)
Re: CAN
There's a new Java update that includes significantly improved CAN Jaguar support. Give it a try.
Brad Miller
Robotics Resource Center
Unread 19-01-2011, 21:05
LukeS LukeS is offline
4272 mentor, 1024 alumnus
AKA: Luke Shumaker
FRC #4272
LukeS is an unknown quantity at this point
Re: CAN
The Java CAN code that shipped (2011.3) this year is non-functioning. We have solved this by using last year's CAN code. Apparently on Monday (January 17), they released 2011.4. The laptop we are using to program has not received this update, so I am not sure if it fixes the issue.
Last year I modified the CAN code to be fault-tolerant. You may be interested in these; I've posted them to this forum somewhere...
Unread 19-01-2011, 22:11
jtdowney jtdowney is offline
Boiler Up
AKA: John Downey
FRC #4302 (Robophins)
jtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant future
Re: CAN
It fixed the issue for my team. You just need to update the Netbeans plugins and redeploy. You'll likely need to do a little code modification as there is a new checked exception from the CANJaguar constructor.
John Downey
Lead Robot Inspector - Purdue IndianaFIRST District
Whitney Young Magnet High School/Robophins (FRC 4302) - Mentor (2013-current)
Midwest Regional Planning Committee - Member (2012-current)
Boilermaker Regional Planning Committee - Member (2011-2014)
Robot Inspector (2008-current)
Purdue FIRST Programs - Staff Advisor (2008-2011)
Lafayette-Jefferson High School/Precision Guessworks (FRC 1646) - Mentor (2006-2011)
Unread 19-01-2011, 22:33
AKA: Luke Shumaker
FRC #4272
Re: CAN
I guessed as much. It's just that the computer I was using isn't regularly connected to the Internet ~ doesn't regularly receive updates, and I didn't notice the update until I got home today. Glad to see wpilibj's finally throwing non-runtime exceptions.
