Re: DAP-1522
The trick to set the SSID with the DAP-1522 in BRIDGE mode is to select SETUP and then WIZARD in the DAP-1522 web interface. Through the wizard interface you can set the SSID to your team number. Otherwise you need to set the SSID in AP mode, then switch back to BRIDGE mode.
dan |
