Re: Constant DAP-1522 Resets
We tried the 12v regulator first, and that gave us constant resets. It was actually more stable on the 5v bus direct from the PDB (where the camera used to connect).
The relevant rule is <R38-B> Quote:
Ok, thanks for the heads-up. Now that you bring it up, it makes sense to me that the regulator should be able to easily compensate for voltage dips, since it's stepping 12v down to 5v. That said, do you think we should be investigating an issue with the regulator or the bridge itself? I'm thinking the regulator...
Oh, that makes sense. Before, we were wiring it to one of the Wagos with a 20 amp fuse. I'll wire it to the 12V on the end and post back. Thanks for your help!
The 12 volt output at the end of the PD is specifically designed to provide 12 volts out even if the input from the battery should fall to 4.5 volts. It is for this reason you must use the 12 volt output connector intended for radio wired to the power convertor provided in the KOP to feed the Dlink.
#7
Thank you so much! That took care of the problem. Now on to line tracking...
