Go to Post The students that I have known in FIRST over my 8 years of involvement have been far more inspired by the competition and some of the jaw dropping creations of "elite" teams than by anything that we made ourselves. - MattB703 [more]
Unread 16-01-2011, 15:19
thepcphysician thepcphysician is offline
FRC #1678
thepcphysician is an unknown quantity at this point
Constant DAP-1522 Resets
Hello everyone,
Our D-Link AP has an unusual problem. On a fully charged battery, it works fine when the robot is disabled. Once the robot is enabled, it works fine in teleop for a few minutes. Then, the AP resets. Once this occurs, we have to wait for the AP to boot back up before we can connect again. Usually, after the battery has been used for more than 3 minutes or so and the first reset has occurred, the small voltage dip caused as the speed controllers initialize causes the AP to reset, making it pretty much undrivable, even though the battery is fresh off the charger and delivers 12.1+ volts.
We were considering placing a capacitor in line with the router (AP) to compensate for the voltage dip. Is this a good idea? We have 4.7 and 10 microfarad capacitors, but we can get other caps if we need to. I have tried unsuccessfully to boot the AP with a capacitor in line, and I'm worried I'm going to kill it if I keep on experimenting. How should I go about wiring this?
Thanks for your help.
Perhaps today is a good day to die!
Unread 16-01-2011, 15:26
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Constant DAP-1522 Resets
Is the converter for the D-Link device wired to the regulated 12V output on the end of the PD previously used for the Wireless Bridge? That voltage should be stable to a very low battery voltage (3 or 4 volts I think).
Unread 16-01-2011, 15:28
FRC #1678
We tried the 12v regulator first, and that gave us constant resets. It was actually more stable on the 5v bus direct from the PDB (where the camera used to connect).
Unread 16-01-2011, 15:32
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
That configuration is not legal and will not pass inspection so I wouldn't put too much time into debugging it.
The relevant rule is <R38-B>
B. The radio power feed must be connected via the 5V converter (model # TBJ12DK025Z) to the marked 12 Vdc supply terminals located at the end of the PD Board (i.e. the terminals located between the indicator LEDs, and not the main WAGO connectors along the sides of the PD Board). No other electrical load can be connected to these terminals (please see the 2011 Robot Power Distribution Diagram posted online at www.usfirst.org/frc/kitofparts for wiring information).
As described in the rule you must use the 12V-5V provided in the Kit of Parts and you must wire it to the 12V supply terminals on the end of the PDB. If you have trouble with that configuration, that is what I would look to troubleshoot.
Unread 16-01-2011, 15:37
FRC #1678
Ok, thanks for the heads-up. Now that you bring it up, it makes sense to me that the regulator should be able to easily compensate for voltage dips, since it's stepping 12v down to 5v. That said, do you think we should be investigating an issue with the regulator or the bridge itself? I'm thinking the regulator...
Unread 16-01-2011, 15:39
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
The 12V regulator on the end of your Power Distribution board (not the Wago connectors along the long edges) should be providing a fairly stable 12V. If it isn't that is where I would start, probably by trying another PDB. If it is providing a stable 12V and your 5V is dipping then I would think the problem is likely with the 12V-5V regulator.
Unread 16-01-2011, 16:03
FRC #1678
Oh, that makes sense. Before, we were wiring it to one of the Wagos with a 20 amp fuse. I'll wire it to the 12V on the end and post back. Thanks for your help!
Unread 16-01-2011, 16:22
The 12 volt output at the end of the PD is specifically designed to provide 12 volts out even if the input from the battery should fall to 4.5 volts. It is for this reason you must use the 12 volt output connector intended for radio wired to the power convertor provided in the KOP to feed the Dlink.
Unread 16-01-2011, 18:22
FRC #1678
Thank you so much! That took care of the problem. Now on to line tracking...
