Go to Post If you use a flux capacitor make certain it is a COTS component, or that you fabricate it from COTS materials. - Richard Wallace [more]
Unread 13-01-2011, 20:32
CaptainChris CaptainChris is offline
FRC #1730
CaptainChris is an unknown quantity at this point
Re: where is the iiko model ?
maya can be transfered from 3ds max
Unread 13-01-2011, 22:57
MrPowers399's Avatar
MrPowers399 MrPowers399 is offline
Team Leader of Dinosaurs
AKA: Austin Reynolds
FRC #0399 (Eagle Robotics)
Team Role: Animator
MrPowers399 can only hope to improve
Send a message via AIM to MrPowers399
Aww the Iiko's are adorable! hahaha thanks!
Anyone else having trouble with the materials? It says "Missing Map Files" then I navigate to the folder with the maps (sceneassets\images\rascal_DIFF_u2_v1.jpg) and click "Use Path" but it still gives me the error.
EDIT: Nevermind I fixed it
Unread 13-01-2011, 23:06
leftybot1515 leftybot1515 is offline
FRC #1515
leftybot1515 is an unknown quantity at this point
Are you positive this is the iiko rig??
it seems a bit too professional for us to use
Unread 14-01-2011, 00:40
Jreed129's Avatar
Jreed129 Jreed129 is offline
animation mentor
AKA: Jeremy Reed
FRC #0103 (Cybersonics)
Jreed129 will become famous soon enough
I believe it is. if you happen to be a little nosy like i am i ready the pdf that is also on the download page and the spell it iiko in that document so it could just be a file mistype...
Unread 14-01-2011, 19:36
FRC #1730
i agree it does seem a little too professional, since i recently started learning 3ds max it is complex for me, but ill do my best,
now has anyone figured out how to key frame this thing
Unread 15-01-2011, 07:42
Lesh_M Lesh_M is offline
FRC #1943
Lesh_M is an unknown quantity at this point
At last! I did it!
1. Select one of the bones.
2. Click the 'Motion' Tab.
3. Expand the 'Layer Manager' rollout.
4. Click and hold the 'Add Layer' button (next to the 'X' button).
5. Point to the first option and release, a new 'Animation Layer' is added.
6. Click the 'Setup/Animation Mode Toggle' button.
7. Start creating keyframes for the spline helpers (like 'CTRL_Head').
Unread 15-01-2011, 14:25
Team Role: Animator
Holy crap.... I deleted all the bones they had and did my own biped rig...
This way is so much better. haha thank you
Unread 15-01-2011, 14:33
Nerd_Skywalker's Avatar
Nerd_Skywalker Nerd_Skywalker is offline
Walker of Skies
FRC #1111
Team Role: Animator
Nerd_Skywalker is an unknown quantity at this point
Originally Posted by Lesh_M View Post
At last! I did it!
When I do this the Rascal CATRig at the bottom doesn't make the iiko move with it. Any suggestions?
Also, the textures don't work with it, when I load the iiko it says something about "Missing External Files" then it gives the directories to the pictures but I see no way to solve it...
Re-dun-dant adj. 1. See redundant
Unread 15-01-2011, 15:00
asciutto asciutto is offline
FRC #1048
asciutto is an unknown quantity at this point
Is it possible to use footstep mode with the CATRig? Or is it possible to convert the CATRig to a Biped?
So far I've only been able to animate with keyframes, but using footstep mode would save a lot of time.
Unread 15-01-2011, 15:47
FRC #1730
powers how did you rig a biped to it, cause that confused me
Unread 16-01-2011, 13:55
Team Role: Animator
With the biped you can't move the mouth or ears like with their rig, but to do it you can delete all of their rigs on it and right click to "Unhide All" and "Unfreeze All" and then delete everything but the Iiko model. Then the rest is just biped rigging. This tutorial is pretty helpful: http://www.ehow.com/way_5980405_3d-s...tutorials.html
Unread 16-01-2011, 16:10
Jreed129's Avatar
animation mentor
AKA: Jeremy Reed
To fix the textures you need to open the material editor get the texture from the iiko rig... then remap to the textures provide by autodesk can be found at ikorig_maxproject\sceneassets\images\
Unread 16-01-2011, 20:14
Walker of Skies
FRC #1111
Team Role: Animator
I'm sorry but what do you mean by "remap"? I have tried loading the textures into the material editor and I just don't know where to put the material...all I have are the CTRLs and the CATRig.
Originally Posted by Eagleeyedan View Post
It's just a .rar file. How do you get it into a .max file?
- Extract the file to the directory of your choice using any popular Extracting program (7zip, WinZip, WinRAR)
- Go to the newly extracted folder
- Go to the "scenes" folder
- Open the file inside in 3ds Max
- Profit*
*Sorry, I couldn't resist
Unread 16-01-2011, 20:24
Eagleeyedan's Avatar
Eagleeyedan Eagleeyedan is offline
C.O.R.E.; We build on each other
AKA: Daniel C.
FRC #2062 (C.O.R.E. 2062)
Eagleeyedan is a jewel in the roughEagleeyedan is a jewel in the roughEagleeyedan is a jewel in the roughEagleeyedan is a jewel in the rough
- Profit*
Thanks!
Unread 16-01-2011, 20:27
AKA: Daniel C.
I can't get the maps on him though. You can't select anything but the dummy objects.
