Go to Post Is there a way to spotlight an entire thread? - ctt956 [more]
Unread 16-01-2011, 10:00
AB Steven AB Steven is offline
FRC #0245
AB Steven is an unknown quantity at this point
Watchdog Problem
Yesterday our team updated all of our computers to Labview 2011 and updated our classmate with the FRC flash drive we got. We tried out the sample drive code and our driver station told us that watchdog wasn't being fed. We also tried some of our own code and still were told watchdog wasn't being fed. Does anyone know how to fix this?
Unread 16-01-2011, 12:30
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Watchdog Problem
Welcome to ChiefDelphi.
I'm not a programmer, but maybe the answer is "Feed the watchdog"?
Use the Search feature in the orange band at the top to find the hundreds of threads on this topic from the last 2 years, surely one of them will have your answer. I recommend doing this.
Unread 16-01-2011, 18:31
FRC #0245
They were supposed to remove watchdog with the 2011 updates. Also, why would the example code that is supposed to run the motors not feed the watchdog if we needed to?
Unread 16-01-2011, 19:37
Try this to narrow down the problem.
  1. Open the block diagram for Begin.vi
  2. Double-click on Drive-Open 2 Motors and open it's block diagram
  3. Change the "enable" input in the center of the screen to "disable"
Run that code to see if the Watchdog message goes away.
Unread 16-01-2011, 20:01
After you installed LabVIEW from the DVD and reimaged the classmate with the usb stick, did you install the labview, utilities, and driver station update and reimage the crio?
Unread 17-01-2011, 02:31
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Also, make sure you are creating a new robot project after having installed all the needed updates listed above. If you have an old project, then it may be enabling the watchdog.
-Joe
Unread 19-01-2011, 17:59
FRC #0245
We disabled that and it still doesn't work. We also added watchdog blocks in teleop and in Robot main, and still no luck. Any more ideas?
Unread 19-01-2011, 18:19
What exactly is the error message you are seeing now?
Unread 19-01-2011, 18:34
FRC #0245
Theres a screenshot of our driverstation.
We did what Mark said, tried a brand new default drive code, and it didn't work. We tried reimaging the cRIO, and the cRIO imaging program tells us that the reimage is complete and successful. But, when we restart the robot our old code from before we updated everything to 2011 is there and still works. Could the problem be that the cRIO isn't reimaging correctly?
Unread 19-01-2011, 18:52
Try this... in Begin, place an open watchdog VI and configure it to be disabled.
Unread 19-01-2011, 18:55
FRC #0245
OK SO our reimagers were keeping the 2010 image instead of defaulting to 2011 now everything is working thanks everyone for posting ideas.
Unread 20-01-2011, 08:17
MaxMax161's Avatar
MaxMax161 MaxMax161 is offline
Allegedly Useful
AKA: Max Llewellyn
FRC #2791 (Shaker Robotics), FRC #1676 (Pascack π-oneers)
MaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond repute
We had the same problem and we fixed it by rewriting all our code in a new robot project. After that we didn't get anymore watchdog errors. If you do end up doing this make sure to find all the .vis in labview again and not copying them from old/other code.
Your only other option is to convert this file to a binary and push it to the crio. http://dogfoodchat.com/wp-content/up...3/Dog-Food.jpg
2791 Shaker Robotics (2013-present)
--Control Systems Mentor 2013-present
--Drive coach 2015-present
1676 The Pascack π-oneers (2010-2013)
--Drive coach 2011-2013
--Lead Programmer 2011-2013
