Go to Post neato. - ebarker [more]
Unread 16-01-2011, 13:45
lastrideelhs's Avatar
lastrideelhs lastrideelhs is offline
AKA: Joe Andre
FRC #0079 (Krunch)
lastrideelhs is an unknown quantity at this point
Modifying TETRIX parts
does anyone know if we are allowed to modify TETRIX parts like bend them or cut them down to size for the minibot?
Unread 16-01-2011, 14:02
dtengineering's Avatar
AKA: Jason Brett
Re: Modifying TETRIX parts
With the exception of the motors, batteries and electronic bits I haven't seen any rules to the contrary (so go for it). Modifying (sometimes heavily modifying) structural and mechanical components is a bit part of FTC and VEX style competitions. Indeed in FRC you can go even further than in VEX or FTC as there is no restriction against welding the Tetrix parts together. (Check alloy composition and tempering before breaking out the TIG, or at least try a few tests on disposable bits, though.)
Jason
Unread 16-01-2011, 14:04
AKA: Joe Andre
FRC #0079 (Krunch)
thank you
Unread 16-01-2011, 19:28
blackrocks0 blackrocks0 is offline
AKA: Chaitanya Chittineni
FRC #2264 (Inceptus)
blackrocks0 is an unknown quantity at this point
I would ask/check on the FRC Q&A before you do it.
Unread 16-01-2011, 22:49
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
Since FTC teams can contribute MINIBOTS to the competition, it's quite likely FTC robot rules are applicable to the minibot.
The FTC 2010 Game Manual allows TETRIX/LEGO parts to be cut, sanded, filed, bent, drilled, milled, etc. per <R11-a>. However, welding or soldering is not permitted per <R11-d>.
I would definitely wait for a Q&A ruling before welding TETRIX parts.
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
Unread 16-01-2011, 22:52
Well, the Q&A did say that welding was acceptable on the Minibot...
But neither the OP nor the GDC specified welding Tetrix parts.
http://forums.usfirst.org/showthread.php?t=16288
Unread 17-01-2011, 08:09
GaryVoshol's Avatar
Cogito ergo arbitro
... it's quite likely FTC robot rules are applicable to the minibot.
I wouldn't make that assumption. If it's not in the FRC manual, it's not part of the FRC game.
(since 2004)
Unread 17-01-2011, 09:30
The minibot is effectively part of the ROBOT, but the minibot rules are also exceptions to main robot rules. Therefore, although Tetrix parts are on the allowed list, the main body of the rule book does not make them untouchable. You can use Tetrix parts on the fullup robot and you may modify any of them under certain conditions. For example you may only modify motors for mounting holes and output shaft. <R93> Motors may not be modified with exceptions of those in Rule <R47>.
<R47> Motors and servos used on the ROBOT shall not be modified in any way, except as follows:
A. The mounting brackets and/or output shaft/interface of the motors may be modified to facilitate the physical connection of the motor to the ROBOT and actuated part.
B. The electrical input leads on the motors may be trimmed to length as necessary.
C. The locking pins on the window motors may be removed.
