Go to Post I respect each member of any FIRST team that is truly trying to help students…how they choose to do so is up to them. - Jason Kixmiller [more]
Unread 16-01-2011, 20:45
mathking's Avatar
mathking mathking is offline
Coach/Faculty Advisor
AKA: Greg King
FRC #1014 (Dublin Robotics aka "Bad Robots")
mathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond repute
Re: Procedural v Object Oriented Programming
From a technical sense, Java does make multiple copies of an object. But in practice this doesn't mean what most people think of as making multiple copies of an object. An object is intantiated in Java, the object references a memory location at which the data is stored. If you create another object and set it equal to the first object (such as when you pass it while calling a method) you do create a copy with the same data. But since that data is the the memory location where the "real" data that defines the object is located, when you change the copy you are changing the original.
OK, that was too confusing. Consider this:
Cat A = new Cat("Kitty");
Cat B = A;
B.changeName("Spike");
System.out.println(A.getName());
/* This code prints out 'Spike' because both A and B are referencing (you can think of it as 'pointing at' if this helps) the same location in memory. */
As for decisions on what language and style to use, as several commenters have posted, you should be asking yourself what is best for the team? And not just for this year but for the future. And you might also consider that using the language with which you are less comfortable will expand your own programming talents.
Thank you Bad Robots for giving me the chance to coach this team.
Rookie All-Star Award: 2003 Buckeye
Engineering Inspiration Award: 2004 Pittsburgh, 2014 Crossroads
Chairman's Award: 2005 Pittsburgh, 2009 Buckeye, 2012 Queen City
Team Spirit Award: 2007 Buckeye, 2015 Queen City
Woodie Flowers Award: 2009 Buckeye
Dean's List Finalists: Phil Aufdencamp (2010), Lindsey Fox (2011), Kyle Torrico (2011), Alix Bernier (2013), Deepthi Thumuluri (2015)
Gracious Professionalism Award: 2013 Buckeye
Innovation in Controls Award: 2015 Pittsburgh
Event Finalists: 2012 CORI, 2016 Buckeye
