Go to Post woo hoo! I rigged up brief Internet access using an old wornout robot battery. - Mark McLeod [more]
Unread 16-01-2011, 21:18
E2207 E2207 is offline
FRC #2207
E2207 is an unknown quantity at this point
Minibot Gearbox
would it be legal to create a gearbox out of polycarbonate gears for the minibot? And how can I calculate the gear ratios for maximum efficiency for the TETRIX motors?
Unread 16-01-2011, 21:37
CrazyCarl461's Avatar
CrazyCarl461 CrazyCarl461 is offline
Power User
AKA: Carl Agnew
CrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant future
Send a message via AIM to CrazyCarl461
Re: Minibot Gearbox
It would be legal to make gears out of polycarb. However, keep in mind that unless they are made to an extremely high level of quality and high tolerances, you may lose more energy in the mesh than you would settling for a less-optimal ratio of the kit gears.
To get the most power out of the motor, find the gear ratio that puts a torque on the motor equal to the torque at max power output. In the case of the Tetrix motors, this is 1.158 Nm. The force input to the system is a known quantity equal to the weight of your minibot and any climbing friction.
My 2011 Build Season Blog
Resistance may be futile, but capacitance has potential!
© All content is protected by the honor system
Unread 16-01-2011, 21:44
The Lucas's Avatar
CaMOElot, it is a silly place
Re: Minibot Gearbox
Motor curves are in this post. Hope it helps
Robot Inspector
Unread 16-01-2011, 23:22
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Re: Minibot Gearbox
What are the specs for the motor with the gear box removed?
http://forums.usfirst.org/showthread.php?t=16187
Unread 18-01-2011, 02:20
vamfun vamfun is offline
Mentor :Contol System Engineer
AKA: Chris
FRC #0599 (Robodox)
vamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of light
Send a message via AIM to vamfun
Re: Minibot Gearbox
Good question... probably could estimate using a gear box efficiency of .5 to .6
It has a 52 :1 gearing and could assume .95% per 5:1 ratio factor.
This seems to be good thread to also get gear_box data.
Anyone weighed a gear_box or have the motor weight w/o box?
Also, what is the gear configuration inside it?
Unread 19-01-2011, 20:23
FRC #2207
Re: Minibot Gearbox
Would it be legal to use a timing pulley? I want to make the gearing ratio possible so that I have more speed and enough torque to move me up the pole quickly. We plan to have our bot under 5lbs. We could also have bevel gears, because space in the minibot is becoming an issue.
