Go to Post "automated chaos" nuff said. - Jferrante [more]
Unread 16-01-2011, 14:17
KART35 KART35 is offline
FRC #1622 (Team Spyder)
Team Role: Electrical
KART35 is an unknown quantity at this point
Question No FIRST tab in wind river? [installation problems]
Hello, I have recently tried installing WindRiver on a few different laptops, the classmate [with the new image], a Windows XP netbook, a desktop with windows 7 x64, and a couple with vista x32.
So far, only one of the vista machines has installed correctly, and the XP netbook is operating correctly (I think). but the rest still don't have the FIRST tab on the menu bar, or the FRC specific example code.
I'm not sure if I can just copy over the entire C:\windriver directory over to the other computers (due to different operating systems). I have tried copying over C:\windriver\workspace (I had noticed there were about 2x the plugins in a certain directory)
If i find a solution i will post it here.
Unread 16-01-2011, 14:34
gvarndell's Avatar
gvarndell gvarndell is offline
Software Engineer
AKA: Addi's and Georgie's Dad
FRC #1629 (GaCo)
Team Role: Parent
gvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond repute
Re: No FIRST tab in wind river? [installation problems]
You can copy the entire Wind River directory from one computer to another.
There's no guarantee doing that will make things work correctly on a 64-bit W7 computer -- even if you're copying *from* a computer where everything worked fine.
Robots never, ever, ever, ever break -- The Robot Repairman (Backyardigans)
Unread 16-01-2011, 18:22
nolanpoe nolanpoe is offline
nolanpoe is an unknown quantity at this point
I had the exact same issue. Just run the workbench update and it will appear. I believe it's available from the usfirst website.
Unread 16-01-2011, 23:12
Thanks a bunch! Will be sure to try this!
