Go to Post People... chill. It is week 1. Recall week 1 last year when many teams said "no one is capping with the 2x ball"... "only a few teams are hanging". - Andy Baker [more]
Unread 16-01-2011, 23:23
Garten Haeska's Avatar
Garten Haeska Garten Haeska is offline
AKA: Garty
FRC #2861 (Infinity's End)
Garten Haeska has a spectacular aura aboutGarten Haeska has a spectacular aura about
TrackerDemoProject
Hello,
I was wanting to try to use the trackers on a mock up robot for this year and when ever i try to look at the Project(click on the link to it in netbeans). It always says "Message
Project:
C:\Users\Developer\Demos\CodeSamples\TrackerDemoPr oject not found!
Any ideas i cant seem to open any of the Sample Projects.
Unread 16-01-2011, 23:30
mwtidd's Avatar
mwtidd mwtidd is offline
AKA: mike
FRC #0319 (Big Bad Bob)
Re: TrackerDemoProject
The tracker demo project is for the camera
The "Line Tracker Project" is for the line trackers
line tracker only has one class:
/* Copyright (c) FIRST 2010. All Rights Reserved. */
/* Open Source Software - may be modified and shared by FRC teams. The code */
/* must be accompanied by the FIRST BSD license file in the root directory of */
/* the project. */
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.DigitalInput;
import edu.wpi.first.wpilibj.DriverStation;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.SimpleRobot;
import edu.wpi.first.wpilibj.Timer;
* Sample line tracking class for FIRST 2011 Competition
* Jumpers on driver station digital I/O pins select the operating mode:
* The Driver Station digital input 1 select whether the code tracks the straight
* line or the forked line. Driver station digital input 2 selects whether the
* code takes the left or right fork. You can set these inputs using jumpers on
* the USB I/O module or in the driver station I/O Configuration pane (if there
* is no Digital I/O module installed.
* Since there is the fork to contend with, the code tracks the edge of the line
* using a technique similar to that used with a single-sensor Lego robot.
* This code worked on a simple bot built from the 2011 kit chassis and weighted
* to behave similarly to complete robot complete with scoring mechanisms. Your
* own robot will likely be geared differently, the CG will be different, the
* wheels may be different - so expect to tune the program for your own robot
* configuration. The two places to do tuning are:
* defaultSteeringGain - this is the amount of turning correction applied
* forkProfile & straightProfile - these are power profiles applied at various
* times (one power setting / second of travel) as the robot moves towards
* the wall.
* In addition: this program uses dead reckoning - that is it drives at various
* power settings so it will slow down and stop at the end of the line. This is
* highly dependent on robot weight, wheel choice, and battery voltage. It will
* behave differently on a fully charged vs. partially charged battery.
* To overcome these limitations, you should investigate the use of feedback to
* have power/wheel independent control of the program. Examples of feedback
* include using wheel encoders to measure the distance traveled or some kind of
* rangefinder to determine the distance to the wall. With these sensors installed
* your program can know precisely how far from the wall it is, and set the speeds
* accordingly.
public class LineTracker extends SimpleRobot {
RobotDrive drive; // robot drive base object
DigitalInput left; // digital inputs for line tracking sensors
DigitalInput middle;
DigitalInput right;
DriverStation ds; // driver station object for getting selections
double defaultSteeringGain = 0.65; // the default value for the steering gain
public LineTracker() {
// create the robot drive and correct for the wheel direction. Our robot
// was geared such that the motor speeds needed to be inverted for
// positive speeds to go forward. You may not need these.
drive = new RobotDrive(1, 2);
drive.setInvertedMotor(RobotDrive.MotorType.kRearL eft, true);
drive.setInvertedMotor(RobotDrive.MotorType.kFront Left, true);
drive.setInvertedMotor(RobotDrive.MotorType.kFront Right, true);
drive.setInvertedMotor(RobotDrive.MotorType.kRearR ight, true);
// set the MotorSafety expiration timer
drive.setExpiration(15);
// create the digital input objects to read from the sensors
left = new DigitalInput(1);
middle = new DigitalInput(2);
right = new DigitalInput(3);
// get the driver station instance to read the digital I/O pins
ds = DriverStation.getInstance();
* This function is called once each time the robot enters autonomous mode.
public void autonomous() {
int binaryValue; // a single binary value of the three line tracking
// sensors
int previousValue = 0; // the binary value from the previous loop
double steeringGain; // the amount of steering correction to apply
// the power profiles for the straight and forked robot path. They are
// different to let the robot drive more slowly as the robot approaches
// the fork on the forked line case.
double forkProfile[] = {0.70, 0.70, 0.55, 0.60, 0.60, 0.50, 0.40, 0.00};
double straightProfile[] = {0.7, 0.7, 0.6, 0.6, 0.35, 0.35, 0.35, 0.0};
double powerProfile[]; // the selected power profile
// set the straightLine and left-right variables depending on chosen path
boolean straightLine = ds.getDigitalIn(1);
powerProfile = (straightLine) ? straightProfile : forkProfile;
double stopTime = (straightLine) ? 2.0 : 4.0; // when the robot should look for end
boolean goLeft = !ds.getDigitalIn(2) && !straightLine;
System.out.println("StraightLine: " + straightLine);
System.out.println("GoingLeft: " + goLeft);
boolean atCross = false; // if robot has arrived at end
// time the path over the line
Timer timer = new Timer();
timer.start();
timer.reset();
int oldTimeInSeconds = -1;
double time;
double speed, turn;
// loop until robot reaches "T" at end or 8 seconds has past
while ((time = timer.get()) < 8.0 && !atCross) {
int timeInSeconds = (int) time;
// read the sensors
int leftValue = left.get() ? 1 : 0;
int middleValue = middle.get() ? 1 : 0;
int rightValue = right.get() ? 1 : 0;
// compute the single value from the 3 sensors. Notice that the bits
// for the outside sensors are flipped depending on left or right
// fork. Also the sign of the steering direction is different for left/right.
if (goLeft) {
binaryValue = leftValue * 4 + middleValue * 2 + rightValue;
steeringGain = -defaultSteeringGain;
} else {
binaryValue = rightValue * 4 + middleValue * 2 + leftValue;
steeringGain = defaultSteeringGain;
// get the default speed and turn rate at this time
speed = powerProfile[timeInSeconds];
turn = 0;
// different cases for different line tracking sensor readings
switch (binaryValue) {
case 1: // on line edge
turn = 0;
break;
case 7: // all sensors on (maybe at cross)
if (time > stopTime) {
atCross = true;
speed = 0;
break;
case 0: // all sensors off
if (previousValue == 0 || previousValue == 1) {
turn = steeringGain;
} else {
turn = -steeringGain;
break;
default: // all other cases
// print current status for debugging
if (binaryValue != previousValue) {
System.out.println("Time: " + time + " Sensor: " + binaryValue + " speed: " + speed + " turn: " + turn + " atCross: " + atCross);
// set the robot speed and direction
drive.arcadeDrive(speed, turn);
if (binaryValue != 0) {
previousValue = binaryValue;
oldTimeInSeconds = timeInSeconds;
Timer.delay(0.01);
// Done with loop - stop the robot. Robot ought to be at the end of the line
drive.arcadeDrive(0, 0);
* This function is called once each time the robot enters operator control.
public void operatorControl() {
// supply your own teleop code here
Unread 16-01-2011, 23:38
AKA: Garty
Where by chance did you find this template?
Unread 16-01-2011, 23:40
mwtidd's Avatar
AKA: mike
within netbeans
new project
samples
frcJava
note that it is NOT in project->frc java
you have to go into samples
