Go to Post just flat out, full force, take no prisoners driving - spears312 [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 16-01-2011, 18:41
LMD3130 LMD3130 is offline
Team Captain
AKA: Liam Driscoll
FRC #3130 (ERRORs)
LMD3130 is an unknown quantity at this point
1.75 steel pipe
I have been experiencing some difficulties on locating 1.75 Steel Pipe to do some tests on where can I find some?
--Preferably a store in Minnesota or a online one to order from--
Unread 16-01-2011, 18:43
Bochek's Avatar
Bochek Bochek is offline
AKA: Adam Bochek
FRC #2200 (MMRambotics)
Bochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud of
Re: 1.75 steel pipe
Your local building supply store should have it in stock, it's called 1.5" EMT
Adam Bochek - FRC 2200
http://www.mmrambotics.com
http://www.watchfirstnow.com
Unread 16-01-2011, 18:45
NOV8R's Avatar
NOV8R NOV8R is offline
AKA: Chuck Brant
FRC #1583
NOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud of
Re: 1.75 steel pipe
You can get it at Home Depot. It's actually 1 1/2 electrical conduit.
Unread 16-01-2011, 19:00
Hallry's Avatar
Hallry Hallry is offline
Dare to be FIRST
AKA: Ryan Hall
FRC #1676 (Pascack Pi-oneers)
Re: 1.75 steel pipe
Its steel emt actually, but yes, it's 1.5, not 1:75
Unread 16-01-2011, 19:53
Dunkin's Avatar
Dunkin Dunkin is offline
FRC #1671 (Buchanan Bird Brains)
Dunkin is an unknown quantity at this point
Re: 1.75 steel pipe
McMaster-Carr is an excellent resource to purchase raw metal materials. They're usually very fast.
http://www.mcmaster.com/#steel-pipe/=amdqzs
Unread 16-01-2011, 21:45
DonRotolo's Avatar
Back to humble
FRC #0832
Re: 1.75 steel pipe
Right. The nominal diameter (i.e., what they call it) is 1-1/2" EMT, but the stuff is just about 1-3/4" in diameter. Like the rules say.
Unread 16-01-2011, 22:04
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: 1.75 steel pipe
Or use top rail for chain link fence, it's the right size. Whatever you have laying around
Unread 16-01-2011, 23:28
Team Captain
AKA: Liam Driscoll
FRC #3130 (ERRORs)
Re: 1.75 steel pipe
Thank you for the help but wont most fences have different dimensions.
Unread 16-01-2011, 23:38
AndyH's Avatar
AndyH AndyH is offline
FRC #1098 (Rockwood Robotics)
AndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud of
Re: 1.75 steel pipe
I was wondering about the surface. I have been testing on 1 3/4 DOM steel tubing. Is the game played with galvanized pipe?
Unread 17-01-2011, 08:58
Generator of Entropy
FRC #2973 (The Mad Rockers)
Re: 1.75 steel pipe
The 1.5 EMT that I bought is galvanized, which I'm pretty sure is standard finish. The OD (per spec) is actually 1.74. This is the material that the official field drawing calls out.
Unread 17-01-2011, 09:48
MrForbes's Avatar
AKA: Jim
Re: 1.75 steel pipe
Chain link fences use standard parts, at least in the US.
It might be difficult to find these materials in different countries.
Unread 17-01-2011, 11:08
Gdeaver Gdeaver is online now
FRC #1640
Re: 1.75 steel pipe
EMT is galvanized coated. Looking at several brands some are very smooth and uniform. Home Depot sample was rough. If I had HD tubing and my bot worked oK, I'd be worried about showing up at the comp and finding FIRST used very smooth and uniform tubing.
