Go to Post When you and your friend consider dressing up as a Potentiometer and “magic smoke” for Halloween! - BX MARK [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 16-01-2011, 22:30
rrossbach rrossbach is offline
AKA: Ron R
FRC #2607 (RoboVikings)
rrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to behold
Legality of Jaguar closed-loop control modes
In an official Q&A answer just posted today, it appears that the Jaguar closed-loop control modes are now not considered competition-legal (see the specific question and answer from the GDC here.)
We're interpreting this to mean that ONLY voltage mode is competition-legal - which is surprising, as we'd previously understood that the essential safety feature of the FMS being able to disable Jaguar-controlled motors was achieved via the special heartbeat sent from FRC_NetworkCommunication, and thus completely protected from any team-written software going awry. Hence the reason for the FRC-specific firmware on the Jags - if the Jag doesn't see the FRC-specific heartbeat, it cuts off the motor output regardless of whether a closed-loop control in the Jag is trying to drive it or not.
Due to the implications of this, we'd like to see if others in the community read this Q&A the same way we have, before we ask GDC for explicit confirmation. Please post your thoughts.
- Ron
Team #2607 controls mentor
FIRST Mid-Atlantic Volunteer
FRC Team #2607 Mentor
Unread 16-01-2011, 22:40
aldaeron aldaeron is offline
AKA: -matto-
FRC #1410 (Kraken)
aldaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond repute
Re: Legality of Jaguar closed-loop control modes
I would post to Q&A before Tuesday so you can get an answer and continue working on your design. It is good to get advice from other folks, but the Q&A ruling is final.
Unread 16-01-2011, 22:48
I thought that was an ambiguous way to answer the question. Is the closed loop control command that does originate from the cRIO the command, or is the calculated voltage output the command? I find it hard to believe that they would make it illegal without outright stating it, so clarification is in order.
Unread 16-01-2011, 23:26
drakesword drakesword is offline
AKA: Bryant
FRC #0346 (Robohawks)
drakesword is on a distinguished road
My interpretation is that you can send the closed loop commands from the cRio.
A Jag may not send closed loop commands to another jag.
Unread 16-01-2011, 23:36
AKA: Ron R
We've posted a Q&A requesting explicit statement of which control modes are competition-legal.
- Ron
Unread 17-01-2011, 00:30
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
The way I see it, the intent of these rules is to keep robots safe. Based on the technology, the cRIO needs to control the Jags so that the Field Management System can stop the robots. That is the point of the FIRST specific Jaguar firmware. All modes are safe and controlled by the FMS.
I expect the GDC will state that all modes are legal.
-Joe
Unread 17-01-2011, 01:10
AKA: Ron R
-Joe
Yep, that's the way we see it too - hopefully the GDC will confirm that understanding.
Unread 17-01-2011, 01:29
There is no rule that prohibits the Jaguars from reading the values from the encoders, however note that Rule R49 requires that the ROBOT must be controlled by the cRIO. In other words, commands may not originate in the Jaguar or any other controller, they must originate in the cRIO.
The commands for the various control moods do originate in the cRIO, it is just that the command is "Set your speed according to these parameters and the encoder".
The key word is command, not data.
Unread 17-01-2011, 08:21
I believe you are right, but then why did GDC find it necessary to say "commands may not originate in the Jaguar" ? In what meaningful sense would this even be possible?
Unread 17-01-2011, 08:42
Ron,
I was under the impression that the heartbeat is to insure that something has not interrupted the CAN connection and therefore allow the Jaguar to continue to execute the last command received. This is something different than a disable command generated by the Crio either through internal firmware for a fault or as received from the FMS. Is this correct?
Unread 17-01-2011, 09:51
I think that half of the response is unrelated. I don't know why they bothered to type it.
A "bad" student could reprogram the Jaguars with entirely new firmware, but this would break several other rules. There would be no doubt that they were doing something illegal though, so I don't know why they bothered to mention it here.
Unread 17-01-2011, 12:12
AKA: Ron R
Ron,
I'd have to let jhersh and/or dyanoshak provide the authoritative answer....but IIRC when the robot is disabled the cRIO stops sending out the FRC "trusted heartbeat" to the Jags, which causes the FRC-specific firmware on the Jag to disable the motor output - not unlike what the standard Jag firmware does when it doesn't see any CAN messages.
Since this "trusted heartbeat" is completely protected from interference - intentional or unintentional - from team software, it's this handshake between the protected FRC software on the cRIO and the FRC-specific firmware on the Jags that provides the required safety, allowing the driver station (or FMS when connected) to disable the Jag motor output, effectively negating any motor output "commands" that come from the team software on the cRIO or the internal control loops on the Jag. That's why the Jags require the special firmware when using CAN in order to be competition-legal.
I see the ambiguity as coming from the terms "reading the values", "command" and "control". Even ignoring the second part of the response, the first sentence is also unclear IMHO.
To quote, adding my own emphasis:
"There is no rule that prohibits the Jaguars from reading the values from the encoders, however note that Rule R49 requires that the ROBOT must be controlled by the cRIO."
Here's a very plausible paraphrase (which is hopefully NOT what the GDC intends):
"There is no rule that prohibits the Jaguars from reading the values from the encoders, however the Jaguars are only permitted to provide the values to the cRIO and all control calculations must be performed on the cRIO."
Seems like we all agree it'd be non-sensical for the GDC to intend this - but it's unclear enough that we had visions of robots being wrongly declared illegal based on different inspectors' opinions.
Unread 17-01-2011, 13:58
Stuart's Avatar
Stuart Stuart is offline
#include coffee.h
FRC #1745 (P51- Mustangs)
Stuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond repute
Send a message via AIM to Stuart
ok so if we interpret this the strictest way possible ( where the jag cant independently make a decision about its output ) wouldn't the current/voltage protection( a jag will shut itself off if it over amps or the voltage gets under 6v) built in to the Jags break this rule?
I dont think that this interpretation is correct ( or will remain correct ).
Proud mentor of Team #1745 the P-51 Mustangs
If at first it doesn't work, use a hammer.
If that doesn't work, use a bigger hammer.
Unread 20-01-2011, 22:13
biojae's Avatar
biojae biojae is offline
Likes Omni drives :)
AKA: Justin Stocking
FTC #5011 (BOT SQUAD) && FTC#72(Garage bots)&& FRC#0399 (Eagle Robotics)
biojae is a jewel in the roughbiojae is a jewel in the roughbiojae is a jewel in the rough
The GDC has spoken, no closed loop control from the jaguar.
http://forums.usfirst.org/showthread.php?t=16326
Originally Posted by FRC GDC
No closed-loop control modes are permitted within the Jaguar per <R62>.
FTC Team 72 - No site
FRC Team 399 - http://www.team399.org
2010 Rockwell Collins Innovation in Control Award - (Use of the CAN bus, among other reasons) Phoenix, Arizona!
Unread 20-01-2011, 23:50
taichichuan's Avatar
taichichuan taichichuan is offline
Software Mentor
AKA: Mike Anderson
FRC #0116 (Epsilon Delta)
taichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud of
Send a message via AIM to taichichuan
Geez. This is a really unfortunate answer from the GDC. It greatly complicates the cabling and increases the complexity of closed-loop control.
Can someone ask on the First forum (it won't let me post) if this means that speed, current and position modes of the Jaguar are prohibited? If so, then there's no reason to use CAN bus. We might as well stay with PWM and the Victors.
Heavy sigh...
