Has anyone gotten weird results from the mecanum drive?
I was working of porting the labview code to java before the kickoff.
At first, the movement was working fine Code:
RobotDrive mecanumWheels = new RobotDrive(1,2,3,4); Joystick joystick = new Joystick(1); mecanumWheels.holonomicDrive(joystick.getMagnitude(), joystick.getDirectionDegrees(), joystick.getTwist()); Code:
RobotDrive mecanumWheels = new RobotDrive(1,2,3,4); Joystick joystick = new Joystick(1); mecanumWheels.mecanumDrive_Polar(joystick.getMagnitude(), joystick.getDirectionDegrees(), joystick.getTwist()); Is it a problem on my end, or on FRC's end? Last edited by kinganu123 : 16-01-2011 at 20:28. |
Re: Has anyone gotten weird results from the mecanum drive?
Have you put it up on blocks and made sure every wheel is powered? Some times you will get these symptoms if every wheel isn't powered for strafe.
like i said, it worked perfectly before the 2011 java update
so i know the wheels aren't the problem and neither is the wiring |
Troubleshooting often involves checking things that you feel certain cannot be the reason for the malfunction. There are many different ways to develop a troubleshooting plan. Most succesful plans keep in mind Occam's Razor. You are inferring that discovering the malfunction after the update indicates explicit causality, however there may be other reasons for the malfunction that are simple to check first. Among the simplest is to put the robot up on blocks and make sure the correct wheels are turning in the correct direction when given an input. This simple step can, at the very least, eliminate some very probable reasons for the malfunction before you dig deeper. Another easy to check cause is to make sure there isn't some code further down that isn't modifying the code that you showed us.
Our wierd symptoms included:
robot spinning while driving forward (gyro shorted on frame) robot swaying like it was dancing (gyro hanging by pwm cable) robot strafing but nothing else (two motors wired reverse) robot spinning and strafing but not moving forward (two motors reversed in program) |
#7
You just described our team's experience for the last week.
This thread explains the cause and solution: http://www.chiefdelphi.com/forums/sh...ad.php?t=89525 We haven't verified the solution but kudos to team 662 for the cause. |
#8
One quick fix is to use mecanumDrive_Cartesian() with the x and y axes as input and a fixed 0 degree angle input. Not ideal though. We have some custom magnitude and direction code for our controller. Not sure if this issue is our code or 2011 wpilibj. I'll be looking into it this weekend. |
#9
See this thread: http://www.chiefdelphi.com/forums/sh...53#post1004753
#10
http://firstforge.wpi.edu/sf/go/artf1315 |
#11
Gonna hafta update the netbook tomorrow |
#12
We ran into another issue today. When strafing the robot goes diagonal. Output from two motors on opposing sides and ends (diagonal from each other) drops to zero which makes it go diagonal.
When we bypass the gyro in the code it goes perfect but doesn't hold heading as to be expected without a gyro. checked output on gyro and it derivatives about 0.05 degrees/second while sitting still. |
#13
Yeah, after updating the netbook, we STILL had problems
We are probably gonna write our own mecanum drive code or get the 2010 version If anyone has the 2010 version on hand, could you direct me to the holonomicDrive. |
#14
-Joe |
#15
The odder thing is when we put arcade in on the mecanum wheels after inverting the back motors it was able to strafe fine. Granted, we could not go straight after the inversion but that is an entire other story. We decided that it would probably be smoother going ahead if the code was rewritten as a way for us to not have to worry about it in future years btw kinganu123: i was in class reading this thread on my phone and was going to respond saying our team has a similar issue, but the saw our number in the corner of my eye . Also i haven't had the chance to start yet. Wednesday I'm looking at it with one of my friends and it should be knocked out by at least Fri, or most of it at least--Nagel |
