Go to Post if you need a hammer you use a hammer and not an oscilloscope. - Andrew Schreiber [more]
Unread 17-01-2011, 00:05
klbarie's Avatar
klbarie klbarie is offline
AKA: Kyle Barie
no team (HOT Team)
klbarie is an unknown quantity at this point
3771 Chassis
Hey, so I am a mentor on team 3771. We are a rookie team this year, and would like to know what you guys think about our chassis design. It will have mecanum wheels and toughbox nanos. let us know!
2009 - 2010: Team 67-The HOT Team-Student
2011: Team 3771-The Yooper Troopers-Mentor
2012: Team 4363-The Unbolted Puppeteers-Mentor
Unread 17-01-2011, 00:08
tonystark_23's Avatar
tonystark_23 tonystark_23 is offline
FRC #2975
tonystark_23 is an unknown quantity at this point
Re: 3771 Chassis
Looks pretty good you guys, but add the electronic components and let us see and we will really be able to judge it! Keep up the good work!!
Unread 17-01-2011, 00:13
klbarie's Avatar
AKA: Kyle Barie
no team (HOT Team)
Re: 3771 Chassis
Will do once we get an arm design settled so we know exactly where to put everything
Unread 17-01-2011, 00:14
ttakashima's Avatar
ttakashima ttakashima is offline
T^2
AKA: Travis
FRC #2504 (The Governors)
ttakashima has a spectacular aura aboutttakashima has a spectacular aura about
Re: 3771 Chassis
Why not try and direct drive the mecanum wheels from the Toughbox-nano? It would save on weight and repair time
Otherwise it looks great. Might i ask how much that weighs approx.
Travis Takashima
Team Leader: Team 4270 - 2016-beyond
Mentor and Team Leader: Team 2504 - 2009-2016
Team 2504 Alum 09'
Attending
-FIRST BAE Systems Hawaii Regional
Unread 17-01-2011, 00:18
Mark Sheridan's Avatar
Mark Sheridan Mark Sheridan is offline
Head Mentor
FRC #3476 (Code Orange)
Mark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond repute
Re: 3771 Chassis
That looks pretty good. I assume that is 1x1" box tubing for the frame. I think you can save some time and weight by removing some of the tubing. I think the pieces that hold the wheels could be removed and you could mount directly to the frame below. Your robot won't be lower but it will save some time when building it. We use 1x1" aluminium box tubing and its pretty tough stuff.
Also, are you using the andy-mark toughbox gearboxes? You can mount two motors to one gearbox. You can shed some weight and time by reducing to two gearboxes for the four motors.
If you want to do 4 wheel drive on a frame that is longer than its width, it will be difficult to turn. The wheels have to have enough force to break its traction in order to slide. You must gear your drivetrain to have enough torque to skid your tires. Many teams use 6 wheel drive with a lowered center wheel to avoid this. You can search the forums about threads on the many benefits of going to 6 wheel drive.
Unread 17-01-2011, 00:19
klbarie's Avatar
AKA: Kyle Barie
no team (HOT Team)
Re: 3771 Chassis
I have been hearing rumors that direct driving mecanums directly from nanos is bad because of the forces put in all those directions. and we are not sure how much it weighs. we are still waiting on our aluminum to come in the mail. But I will try and post here the weight of it once we have i assembled.
Unread 17-01-2011, 00:22
ttakashima's Avatar
T^2
AKA: Travis
Re: 3771 Chassis
They stated that they will be using mecanum wheels, all 4 need to be driven independently to strafe.
Also the toughbox-nano only accepts 1 CIM motor, I believe those Toughboxes and wheels are only place holders.
Travis Takashima
Team 2504 Alum 09'
Attending
Unread 17-01-2011, 00:24
klbarie's Avatar
AKA: Kyle Barie
no team (HOT Team)
Re: 3771 Chassis
Its going to be mecanum wheels and toughbox nanos, so we will need all the separate motors and gearboxes. and with the bumper zone being so low to the ground this year, we wanted to get the wheels as much into the frame as possible.
Unread 17-01-2011, 00:25
klbarie's Avatar
AKA: Kyle Barie
no team (HOT Team)
Re: 3771 Chassis
what he said XD
Colin P's Avatar
Colin P Colin P is offline
MTU Robotic Systems Enterprise
AKA: Colin Putters
FRC #0857 (Da Yooper Troopers 3771, Unbolted Puppeteers 4363)
Colin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to behold
Re: 3771 Chassis
Precisely
Unread 17-01-2011, 00:28
Head Mentor
Re: 3771 Chassis
Oh whoops, that makes a lot more sense.
Unread 17-01-2011, 00:30
ttakashima's Avatar
T^2
AKA: Travis
Re: 3771 Chassis
Are you getting 2x1 box alum. in the mail as well? If you are you should look into using that. You could eliminate the top structure and reduce weight.
Travis Takashima
Team 2504 Alum 09'
Attending
Unread 17-01-2011, 00:33
klbarie's Avatar
AKA: Kyle Barie
no team (HOT Team)
Re: 3771 Chassis
unfortunately, no. i had thought about that after we had ordered all of our stock. hope we can live with that extra pound or two, and we wont be drilling holes in it when it comes time to weigh in XD
Unread 17-01-2011, 00:36
ttakashima's Avatar
T^2
AKA: Travis
Re: 3771 Chassis
i believe our 2009 robot had about 1000 holes in it, all of different sizes... took us 3 days to reduce our weight by 5 or 6 pounds... though we were using 80-20 material...
Travis Takashima
Team 2504 Alum 09'
Attending
Unread 17-01-2011, 00:39
klbarie's Avatar
AKA: Kyle Barie
no team (HOT Team)
Re: 3771 Chassis
XD hopefully none of us have to go through that this year.
