Go to Post You will find friends among all FIRST students who will become very good friends of yours, will care and help you with anything that you need help with. This is my personal opinion, If you are hooked, dont ever let it go. - Arefin Bari [more]
Unread 17-01-2011, 00:13
meakerb's Avatar
meakerb meakerb is offline
FRC #3786
meakerb is an unknown quantity at this point
Powered Game Piece Release
At the start of the match, an Ubertube is to be in contact with the robot. For most robots that have a gripper or other electro-mechanical means of holding the game pieces, this would involve running a motor to open the gripper and then close it on the game piece.
Then at the end of the match, the robots that are holding game pieces would also have to be "run" so that their grippers would open to release the game pieces.
However, the field system will not allow you to "run" your robot before or after a match. Does this mean that the teams will need to bring their classmates (PCs) onto the field and connect directly to them (teathered ethernet connection) in order to open/close their manipulator hands?
Mentor, team 3221
Unread 17-01-2011, 00:18
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Powered Game Piece Release
It would be wise (and perhaps even required) to design a system that does not require tethering to release a game piece. There are a number of ways to do that, including but not limited to:
1) Software control that always opens the gripper right before the end of the match
2) A backdriveable gripper
3) A pneumatic gripper (releasing the pressure vent valve releases the game piece)
4) Designing some type of "manual override" where you can open the gripper without backdriving the motor.
Unread 17-01-2011, 01:11
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
most of the time you can backdrive whatever manipulator you have
Unread 17-01-2011, 02:09
ttakashima's Avatar
ttakashima ttakashima is offline
T^2
AKA: Travis
FRC #2504 (The Governors)
ttakashima has a spectacular aura aboutttakashima has a spectacular aura about
unless you are using the window motors. worm drive gear box = cant backdrive without power.
you would need to:
Travis Takashima
Team Leader: Team 4270 - 2016-beyond
Mentor and Team Leader: Team 2504 - 2009-2016
Team 2504 Alum 09'
Attending
-FIRST BAE Systems Hawaii Regional
Unread 17-01-2011, 02:14
Chris is me's Avatar
AKA: Pinecone
Most grippers should be backdriveable so you can force the tubes out to remove game pieces. The only exception would be a window motor based gripper which would need something else to slip.
Unread 17-01-2011, 02:15
NorviewsVeteran's Avatar
NorviewsVeteran NorviewsVeteran is offline
Precision Driver Extraordinaire
AKA: Richard Raitt
FRC #1793 (Pilots)
NorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond repute
In '07, one thing we did right was open the jaw with a bicycle brake cable, and it was closed with a spring. This allowed us to manually open the jaw with no problem.
______
I was in Scouts but I wanted out by the third meeting. I was in TSA, but I quit after a couple of weeks. I don't go camping with the SCA anymore. I was in taekwondo but I had to leave because I got sick.
I joined FIRST and stuck with it. It was nice enough to return the favor.
