Go to Post But that deals with quantum phys-- ooh, shiny objects. - Otaku [more]
Unread 17-01-2011, 00:21
RoboMaster's Avatar
RoboMaster RoboMaster is offline
Alum, former programmer&co-captain
FRC #2472 (The Centurions)
RoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant future
Re: Pressure Sensor
Originally Posted by josneville View Post
We were going to use a magnetic reed switch which will make the bimbo (im still not sureabout the name) stop at certain levels. Any idea on how to program that????
This is not a programming problem. It is a physical issue. As described by Don, an pneumatic piston can only be fully out or fully in. There are ways to make it stop in, say, the middle, but they are not FRC accessible. You need special hardware to do it easily. Even with the pneumatic hardware we can use from the Kit, I don't even think it would be possible, much less just difficult, to hook up and control a piston in this way.
My engineering blog: noeticbrainwaves.blogspot.com
I'm not slacking, my code's compiling
...and I'm using LabVIEW
